VLC can view camera stream, but ZM can't
Support for the docker image maintained by dlandon
Rohlex32
Post by Rohlex32 »
I was able to find the rtsp url using Windows' ONVIF Device Manager. From there I was able to view the camera stream from ONVIF Device Manager and from VLC network stream.
Settings:
Source Type: Ffmpeg
Source Path: rtsp://admin:<mypassword>@<ip>:554/media/video1
Method: TCP
Capture Resolution: 1920x1080 (same as what VLC lists)
I have the PATH_ZMS variable assigned to "/zm/cgi-bin/nph-zms", and haven't been receive any errors there.
If anyone had some hints or tips to help me identify why my Zoneminder container can't communicate with my network camera that would be appreciated!
docker-compose.yml:
version: '3'
services:
  zm:
    image: dlandon/zoneminder:latest
    container_name: zm
    privileged: "true"
    ports:
      - "8443:443/tcp"
      - "9000:9000/tcp"
    volumes:
      - /mnt/Zoneminder:/config:rw
      - /mnt/Zoneminder/data:/var/cache/zoneminder:rw
    env_file: .env
.env file:
TZ="America/Chicago"
SHMEM="50%"
PUID="99"
PGID="100"
INSTALL_HOOK="0"
INSTALL_FACE="0"
INSTALL_TINY_YOLO="0"
INSTALL_YOLO="0"
MULTI_PORT_START="0"
MULTI_PORT_END="0"
PATH_ZMS="/zm/cgi-bin/nph-zms"
Logs are attached below
zm-log.txt
(946.38 KiB) Downloaded 277 times
Re: VLC can view camera stream, but ZM can't
Start with the fatal errors in the log. Like this one
No host specified for remote camera
Sounds like the monitor is wrongly configured in ZM.
Rohlex32
Post by Rohlex32 »
SOLVED: I added 2 additional lines to my docker-compose file. I'm not sure if the 'network_mode: "bridge"' helped, but the 'shm_size: 8G' definitely did.
version: '3'
services:
  nvr:
    container_name: nvr
    privileged: "true"
    restart: always
    ports:
      - "8443:443/tcp"
      - "9000:9000/tcp"
    volumes:
      - /mnt/Zoneminder/config:/config:rw
    shm_size: 8G
    env_file: .env
