Hi All,
Long time Zoneminder user but wanting to leverage the awesome work on event notification server and wanted to give this container image a go. Unfortunately I can't get it to work, despite retrying using a copy and paste of the commands off the git page. I've attached full log and below snap show of command i used and logs. Any pointers most appreciated. I am running Docker on Ubuntu 20.04 server
docker pull dlandon/zoneminder
docker run -d --name="Zoneminder" \
--net="bridge" \
--privileged="true" \
-p 8443:443/tcp \
-p 9000:9000/tcp \
-e TZ="America/New_York" \
-e SHMEM="50%" \
-e PUID="99" \
-e PGID="100" \
-e INSTALL_HOOK="0" \
-e INSTALL_FACE="0" \
-e INSTALL_TINY_YOLO="0" \
-e INSTALL_YOLO="0" \
-e MULTI_PORT_START="0" \
-e MULTI_PORT_END="0" \
-v "/mnt/Zoneminder":"/config":rw \
-v "/mnt/Zoneminder/data":"/var/cache/zoneminder":rw \
dlandon/zoneminder
Event Server version: '5.13-Docker'.
Using existing ssmtp folder
Using existing mysql database folder
Copy /config/control/ scripts to /usr/share/perl5/ZoneMinder/Control/
Copy /config/conf/ scripts to /etc/zm/conf.d/
Creating symbolink links
chmod: cannot access '/config/control/*': No such file or directory
Using existing data directory for events
Using existing data directory for images
Using existing data directory for temp
Using existing data directory for cache
Correcting /var/cache/zoneminder/cache permissions...
no crontab for root
Setting shared memory to : 50% of 32888968 bytes
Starting services...
* Starting MariaDB database server mysqld
...fail!
DBI connect('database=zm;host=localhost','zmuser',...) failed: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) at /usr/share/perl5/ZoneMinder/Database.pm line 110.
May 28 19:15:04 901612a4391a zmupdate[12429]: ERR [Error reconnecting to db: errstr:Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) error val:]
Starting MariaDB database server mysqld ..Fail!
- Container.txt
- (35.64 KiB) Downloaded 1387 times
Re: Starting MariaDB database server mysqld ..Fail!
Same thing here. The container cannot start MariaDB and exits.
I've been running this image for close to a year without too much trouble. I did install native apache2 and mariadb on this host a couple days again. I assume that broke it? But Docker is suppose to keep that separate, right?
Edit 6/2/2020 -- I followed the guide below to fix a problem with apparmor stopping mariadb:
https://mariadb.com/kb/en/the-community ... -when-try/
Edited my post with link that fixed it for me. Something in a recent ubuntu upgrade broke mariadb/apparmor. Manually disabling apparmor's mysqld profile and rebooting worked. Just restarting apparmor did not work for me, had to reboot.
Hey!
May you please clarify the steps needed in order to get the container to start? i do not get how to apply linked fix on a docker run. Does fix apply for docker?
Looking forward for your help!
You need to run the commands against the host environment. The second solution of a temporary disable did not work for me at all, but the first solution (removing the offending profile) on the host seems to have resolved the issue.
A first solution is to disable only the problematic Apparmor profile.
$ sudo ln -s /etc/apparmor.d/usr.sbin.mysqld /etc/apparmor.d/disable/
$ sudo apparmor_parser -R /etc/apparmor.d/usr.sbin.mysqld
Verify:
$ sudo aa-status
