With docker, you have to let the container start, and that can take maybe 1-5 minutes (depending on container complexity). If you interrupt the container before it finishes its startup, it will be in a broken state. At that point, you have to delete the container and start over.Littlefoot wrote: ↑Fri May 15, 2020 1:00 pm Followed the instructions from here: https://github.com/dlandon/zoneminder
The only change to the instructions I made was replacing the '0's with 1's for running assuming I want all the extras.
1- I tried rebooting but no luck.
2- I tried using the same sudo docker run -d --name="Zoneminder" \ and the rest but it tells me the container is already in use.
3- I also have no idea how to access it. When I tried ZM back in 2017 I just used localhost/zm in it displayed. I tried as the instructions 'https://<MyMachiesIP>:8443/zm but no luck.
4- If I do an 'ifconfig' it has added 'docker0:' but it's on a different Ip address, netmask and broadcast.
5- Do I / should I have installed lamp python php and mysql or such before hand. Does the docker need them?
100% novice so I have no idea.
To do so:
docker kill <containername> (stops running container)
docker rm -f <imagename> (deletes image - not container)
See also:
docker ps (list running containers)
docker images (list images)
For your docker run command, I would advise you look into docker-compose. That is easier to manage than the command line.
That is a start. You might want to get a book on docker. Adrian Mouat has a good intro book.
The docker does not require any other dependencies (LAMP). It should include everything, and run with a single command.
