Docker upgrade
Support for the docker image maintained by dlandon
EK701
Docker upgrade
Post by EK701 » Thu Feb 06, 2020 4:29 pm
I’m currently running the 1.32.4 dlandon docker image. What is the proper way to upgrade to the 1.34 docker image without losing my existing configuration and database?
Thanks!
snake
Re: Docker upgrade
Post by snake » Fri Feb 07, 2020 5:23 am
I can't speak for docker w/zm (hopefully someone else will chime in) but you can always backup the db and then go back / restore should something go wrong.
For docker, a quick search online comes up with this command for backing up a mysql db:
# Backup
docker exec CONTAINER /usr/bin/mysqldump -u root --password=root DATABASE > backup.sql
# Restore
cat backup.sql | docker exec -i CONTAINER /usr/bin/mysql -u root --password=root DATABASE
In ZM, if you have the db, you have the configuration. You may lose events, however.
EK701
Re: Docker upgrade
Post by EK701 » Tue Feb 11, 2020 10:47 pm
Just a follow up that I upgraded my zoneminder docker installation using the typical docker upgrade path (docker stop, rm, run a new instance) without any issues.
warcanoid
Re: Docker upgrade
Post by warcanoid » Wed Feb 26, 2020 7:22 pm
If I can ask here. I have mounted a second internal drive to ZM. Added disk to fstab in host and docker. But on system reboot docker wont auto mount disk(only host do it). How can I make auto mount disk persistent in docker?
EDIT: Have reinstalled Zoneminder with `v "/media/zm":"/mnt/ZM`, and working with path /mnt/ZM
sudo docker run -d --name="Zoneminder" --net="bridge" --privileged="true" -p 888:80/tcp -p 9001:9001/tcp -e TZ="Europe/Berlin" -e SHMEM="50%" -e PUID="99" -e PGID="100" -e INSTALL_HOOK="1" -e INSTALL_FACE="1" -e INSTALL_TINY_YOLO="1" -e INSTALL_YOLO="1" -v "/mnt/Zoneminder":"/config":rw -v "/mnt/Zoneminder/data":"/var/cache/zoneminder":rw -v "/media/zm":"/mnt/ZM":rw dlandon/zoneminder
dlandon
Re: Docker upgrade
Post by dlandon » Sat Feb 29, 2020 7:18 pm
All you have to do is restart the docker and ZM wll be updated. All database files and setup are kept in the /config/ folder. Thus is the nice thing about dockers, your data is not kept in the docker image. You can delete the image and re-install it and your database and settings will be kept.
If you are updating the docker itself, you will have to remove it and re-install the docker.
Minglarn
Re: Docker upgrade
Post by Minglarn » Fri Dec 04, 2020 1:04 pm
So for a noob like me, how would the upgrade process be if I consider upgrading your docker?
//Best regards...
Re: Docker upgrade
Post by Magic919 » Fri Dec 04, 2020 3:27 pm
If you want to upgrade ZM ,then restart the Docker container.
Minglarn
Re: Docker upgrade
Post by Minglarn » Sun Dec 06, 2020 1:17 pm
You mean by doing:
docker rm Zoneminder
and
docker run -d --name="Zoneminder" \
--net="bridge" \
--privileged="true" \
-p 8443:443/tcp \
-p 9001:9001/tcp \
-e TZ="SE/Stockholm" \
-e SHMEM="50%" \
-e PUID="99" \
-e PGID="100" \
-e INSTALL_HOOK="1" \
-e INSTALL_FACE="1" \
-e INSTALL_TINY_YOLOV3="0 \
-e INSTALL_YOLOV3="0" \
-e INSTALL_TINY_YOLOV4="1" \
-e INSTALL_YOLOV4="" \
-e MULTI_PORT_START="0" \
-e MULTI_PORT_END="0" \
-v "/mnt/Zoneminder":"/config":rw \
-v "/mnt/Zoneminder/data":"/var/cache/zoneminder":rw \
dlandon/zoneminder
Re: Docker upgrade
Post by Magic919 » Sun Dec 06, 2020 2:32 pm
Yes, a stop, rm, run should do it. For other images I usually run a pull, but above here you can see the author says restart is enough.
Minglarn
Re: Docker upgrade
Post by Minglarn » Sun Dec 06, 2020 3:31 pm
Great.. Just needed to be sure... Did a restart but it did not pull the newest container...
Thanks.
