Object recognition
hahobson
Object recognition
Post by hahobson »
Hello, I have installed ZM and the Event Server. How would I add a simple HAAR Cascade application? This is what I have working:
import numpy as np
import cv2
dog_cascade = cv2.CascadeClassifier("cascade.xml")
cap = cv2.VideoCapture("rtsp://192.168.0.51:8080/h264_ulaw.sdp")
while 1:
    ret, img = cap.read()
    gray = cv2.cvtColor(img, cv2.COLOR_BGR2GRAY)
    dog = dog_cascade.detectMultiScale(gray, 1.05, 11)
    for (x,y,w,h) in dog:
        cv2.rectangle(img,(x,y),(x+w,y+h),(255,0,0),2)
        roi_gray = gray[y:y+h, x:x+w]
        roi_color = img[y:y+h, x:x+w]
    cv2.imshow('img',img)
    k = cv2.waitKey(30) & 0xff
    if k == 27:
        break
cap.release()
cv2.destroyAllWindows()
I have looked at the objectconfig.ini file, but not sure how to add code to Zoneminder. Thank you!
asker
Re: Object recognition
Post by asker »
This is not something you can turn on via a config - will require code level integration.
Here is the high level flow to get you started:
1. You will need to make these changes in pyzm
2. pyzm/ml/object.py is the wrapper for all things object detection related (person is an object in this context)
3. You will need to add a new 'object_framework' type called, say, 'hog' and invoke your class there (in object.py)
4. Write your hog class similar to other classes
5. Make sure it is installed as part of setup.py
To make this more concrete, take a look at this pull request, where a contributor added AWS rekognition support.
Note that at one point, I had hog support built in, but removed it. You'll see hog.py inside pyzm/ml which you can modify.
Please read before posting:
ES docs
zmNinja docs
