Configuration file containing camera settings
manny99
Post by manny99 »
Is there a possibility to insert manual settings of camera in configuration file?
My camera goes in capturing mode but I have red colour in camera name and ip columns. Camera work perfect with vlc on windows pc but not work on zoneminder installed in my raspberry pi 4.
I need the file name where insert camera parameters manually.
Thank you
Maximo1970
Re: Configuration file containing camera settings
Post by Maximo1970 »
I can't answer your question directly, but will try and offer some form of help.
As you say the camera works fine via VLC, so it should also work with ZoneMinder. Can you share the current configuration for the camera as it could be that you've either missed something or someone may have an alternative for you. I don't think ZoneMinder uses separate config files as the main data repository store is the MySQL/MariaDB database.
The following would be useful.
General Tab
Source Type:
Source Tab
Source Path:
Method:
Options:
DecoderHWAccelName:
DecoderHWAccelDevice:
Seems like the same question as the other thread.
