Montage freezes browser
kradoow
Post by kradoow »
I find Montage impossible to use. Currently, I use montage review, which works for the most part but I would like to be able to use Montage. When I use the Montage view it totally freezes my browsers, Firefox/Chrome. Everything just hangs for several seconds, 30+.
Re: Montage freezes browser
Sounds like you have more than 4 cameras, which means you need multi-port.
kradoow
Post by kradoow »
Thanks for the reply. I made changes to iptables
viewtopic.php?t=28168
It is now functioning!!!!
kradoow
Post by kradoow »
oops, spoke too soon. Now I cannot get zmninja on android to display anything
DACS
Post by DACS »
I have found a similar problem when using Firefox on the Ubuntu system where ZoneMinder is running. The whole system would freeze after a short period, nor just the browser but Ubuntu itself.
I changed the browser to Chromium and montage now works correctly.
