...from a new Zoneminder-user. I hope so to be one....
I install a Debian Stretch with that https://zoneminder.readthedocs.io/en/la ... an-stretch help.
Stretch runs at a proxmox 6.3.6 on a OdroidH2+
After install with no prob´s runs Apache Server but if i try to load the ZM Gui (http://192.168.2.4:81/zm/) at Chrome all what i see is a clean window.
I was changing the Port in both files from 80 to 8080 and in end to 81....dont works.
Shell show me:
root@Debian9:~# systemctl status zoneminder
* zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2021-04-11 13:28:06 UTC; 16min ago
Process: 360 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
Main PID: 422 (zmdc.pl)
Tasks: 6 (limit: 4915)
CGroup: /system.slice/zoneminder.service
|-422 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
|-451 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
|-457 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
|-464 /usr/bin/perl -wT /usr/bin/zmwatch.pl
|-470 /usr/bin/perl -wT /usr/bin/zmupdate.pl -c
`-475 /usr/bin/perl -wT /usr/bin/zmstats.pl
Apr 11 13:28:06 Debian9 zmwatch[464]: INF [Watchdog starting, pausing for 30 seconds]
Apr 11 13:28:06 Debian9 zmdc[422]: INF ['zmupdate.pl -c' starting at 21/04/11 13:28:06, pid = 470]
Apr 11 13:28:06 Debian9 zmdc[470]: INF ['zmupdate.pl -c' started at 21/04/11 13:28:06]
Apr 11 13:28:06 Debian9 sudo[472]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-dat
Apr 11 13:28:06 Debian9 sudo[472]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Apr 11 13:28:06 Debian9 zmdc[422]: INF ['zmstats.pl' starting at 21/04/11 13:28:06, pid = 475]
Apr 11 13:28:06 Debian9 zmdc[475]: INF ['zmstats.pl' started at 21/04/11 13:28:06]
Apr 11 13:28:06 Debian9 sudo[472]: pam_unix(sudo:session): session closed for user www-data
root@Debian9:~# journalctl -xe
-- Unit phpsessionclean.service has finished starting up.
-- The start-up result is done.
Apr 11 13:43:36 Debian9 systemd[1]: systemd-tmpfiles-clean.service: [b]Failed to reset devices.list: Operat[/b]
Apr 11 13:43:36 Debian9 systemd[1]: systemd-tmpfiles-clean.service: [b]Failed to set invocation ID on contr[/b]
Apr 11 13:43:36 Debian9 systemd[1]: Starting Cleanup of Temporary Directories...
-- Subject: Unit systemd-tmpfiles-clean.service has begun start-up
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Unit systemd-tmpfiles-clean.service has begun starting up.
Apr 11 13:43:36 Debian9 systemd[1]: Started Cleanup of Temporary Directories.
-- Subject: Unit systemd-tmpfiles-clean.service has finished start-up
-- Unit systemd-tmpfiles-clean.service has finished starting up.
Apr 11 13:51:01 Debian9 CRON[590]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 11 13:51:01 Debian9 CRON[591]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Apr 11 13:51:01 Debian9 CRON[590]: pam_unix(cron:session): session closed for user root
lines 588-609/609 (END)
Have a nice sunday, Frank
