Page 1 of 1
Zoneminder Event notification server gpu object detection mlapi proxmox
Posted: Thu Mar 25, 2021 9:00 pm
by JasonBorn
Hey all,
Im a little bit confused about to setup a mlapi server and other things.
Do i have to Install the notification server on the zoneminder server AND the mlapi server?
Would it be bether to create an lvm or an lxc for zoneminder/object detection?
Is there anybody who installed tensorflow/cuda/cudnn/opencv at the last time? I tried it 10+times but it wont work. Everytime it stucks on cuddn : no. Maybe someone can help me in this case.
Thanks for your help
EDIT: I solved the issue with cudnn. Just used the new version of opencv. Can someone help me with my other questions?
Re: Zoneminder Event notification server gpu object detection mlapi proxmox
Posted: Sat May 15, 2021 5:48 am
by JasonBorn
can you help me please? Do i have to install mlapi on the same server as the ES and the ZM or can i install mlapi on a different server?
Posted: Sat Jun 05, 2021 7:45 am
by JasonBorn
ok, solved. I dont have to install the zmeventnotification on the mlapi sever as well.
