account_circle, add_circle and other display issues
ZonedOut
Post by ZonedOut » Wed Mar 17, 2021 12:59 am
I see posts with similar issues but none seem to apply to the following:
Logging in with a local IP everything is fine.
Logging in externally I see "account_circle" instead of the user logo. Once logged on there are various similar placeholders (eg add_circle) and the display is generally messed up. However I can access zoneminder externally with zmninja which is fully functional.
As a side note: My apache config redirects all http traffic to https (or at least I think it does as an http url is successfuly changed to https on external access). However certbot renewal works, but I thought it needed to be excluded redirection. Anyway I mention this (otherwise off topic) in case it has any bearing on the problem. It may also be worth noting the local zoneminder access requires me to add a certificate exception.
I can t see the above could be linked to my issue, but hopefully someone can point me down the right path.
Zoneminder 1.24.2, 4 Logitech usb webcams, Intel Pentium M 32 bit 1.4GHz, 500KB, Ubuntu 10.4
Building Zoneminder 1.24.4, 1 Logitec usb webcam, Core2Duo e6600 2.4GHz, 2GB.
Users browsing this forum: No registered users and 5 guests
