Trying to connect a AXIS M2026-LE Mk II camera using
rtsp://onvifuser:pw@192.168.0.76/onvif-media/media.amp?profile=profile_1_h264
Getting this in the log:
Unable to open input rtsp:///onvifuser:pw@192.168.0.76/onvif-media/media.amp?profile=profile_1_h264 due to: Server returned 5XX Server Error reply
zm_ffmpeg_camera.cpp
394
ZM version 1.34.22
Any ideas? Thanks
AXIS M2026-LE Mk II 5XX error
Re: AXIS M2026-LE Mk II 5XX error
This is the error from the debug in ffmpeg: zmc_m2[15254]: WAR [zmc_m2] [method DESCRIBE failed: 503 Service Unavailable]
(Should be posted in hardware compatibility.)
See https://wiki.zoneminder.com/Finding_Camera_Stream_Paths
Try ffmpeg from terminal. Try VLC from gui. Do those work?
Sounds like the path is wrong. Are you sure that path works with ffmpeg/vlc?
fastest way to test streams:
