First time poster here. I recently upgraded from 1.30.x to 1.34.22 and mergerfs has not behaved the way it used to be. When a drive is filled up, I expect mergerfs to look for available space of other drive(s) in the pool and writes the data there. This had worked fine with 1.30.x but not with 1.34.x. In this new build, once the first drive is filled up, I would get many error messages like this
Dec 10 01:02:42 PC10 zma_m1[5590]: ERR [zma_m1] [Can't open /mnt/virtual/zoneminder/events/1/2020-12-10/96247/02968-capture.jpg for writing: No space left on device]
When I manually create a file using the touch command,
touch /mnt/virtual/zoneminder/events/test.txt
Here are things that I have done
- Set the Option > Storage> Path is set to /mnt/virtual/zoneminder/events, the virttual path of mergerfs.
- Confirmed the DiskSpace in Option menu shows correct used and total values of the mergerfs pool.
- Created a /etc/zm/conf.d/03-events.conf and added ZM_DIR_EVENTS=/mnt/virtual/zoneminder/events
- Set owner and permission of the virtual drive to www-data
drwxrwxrwx 4 www-data www-data 4096 Dec 2 15:18 virtual
Please help. Many thanks in advance.
[UPDATE:]
It was a mergerfs issue after all. After adding
category.create=lfs
