I used zononemider 1.34.22, the zoneminder fill up the rootsystem 100% on ubuntu 20.04.
Anybody know how to fix this problem, let's help me, please?
How to fix the zoneminder fill up rootsystem 100%
Re: How to fix the zoneminder fill up rootsystem 100%
Use your lvm tools to create a separate partition for event storage and configure ZM to use it.
Or just install a separate drive.
@pedula: Let's help me step-by-step to change the location of the ZM event log, please?
In ZM it's Options.Storage.AddNewStorage.
Point it to your new mount you created (either new drive or moved partitions)
Then go to each camera config and on the storage tab, select the storage you created above.
