zmevennotification object detection on edge tpu
Re: zmevennotification object detection on edge tpu
Post by Magic919 » Sat Nov 21, 2020 11:33 am
Now it’s getting dark earlier I find the TPU results are pretty hilarious in the dark. It recognised a rock as a person. I went back to CPU.
asker
Post by asker » Sat Nov 21, 2020 4:10 pm
So do you think possible on mlapi to use YoloVx only after MobileNetSSDV2 if MobileNetSSDV2 return nothing or no patern filter
[objectfirst]
[objectsecond]only if first failed
Not yet, but the plumbing is already in place.
The new version of pyzm allows you to:
a) chain models and fallback to different ones
b) Analyze arbitrary frames
c) Select based on multiple criteria (example within a given pattern, match the most objects, or most unique objects etc)
https://github.com/pliablepixels/pyzm/b ... /stream.py
If you are comfortable experimenting in python, you can code this out yourself as well using pyzm.
What is done so far: the hard part - the chaining/streaming/filtering/detection (80% of the work)
What is left: integrating with zm_detect and mlapi (20% of the work)
Of course, the 20% I'm not finding time for
Please don't ask me questions via PM. Feel free to post in the forums or Github
fennec
Post by fennec » Sat Nov 21, 2020 7:19 pm
ok thanks little experience on python
i see that
thanks
fennec
Post by fennec » Sat Nov 28, 2020 12:16 pm
do you try another models ?
https://coral.ai/models/
all model works in Input size: 224x224
but no resize for height |---------- TPU (input image: 224w*125h) ----------|
Normal ?
VicThor
Post by VicThor » Tue Jan 05, 2021 8:46 pm
https://coral.ai/news/updates-11-2020/
Has anyone tried MobileDet SSD ?
How does it compare to yolo ?
VicThor
Post by VicThor » Wed Jan 06, 2021 1:42 am
I guess I can answer my own question :)
The new library will break zmeventnotification as it removes python3-edgetpu
sudo apt-get install python3-pycoral
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
libedgetpu1-std python3-tflite-runtime
The following packages will be REMOVED:
python3-edgetpu
The following NEW packages will be installed:
python3-pycoral python3-tflite-runtime
The following packages will be upgraded:
libedgetpu1-std
Which will break zmdetect:
/zm_detect.py[1931]: FAT [zmesdetect_m3] [Unrecoverable error:No module named 'edgetpu' Traceback:Traceback (most recent call last):#012 File "/var/lib/zmeventnotification/bin/zm_detect.py", line 849, in <module>#012 main_handler()#012 File "/var/lib/zmeventnotification/bin/zm_detect.py", line 321, in main_handler#012 m = object_detection.Object(logger=g.logger, options=g.config)#012 File "/usr/local/lib/python3.8/dist-packages/pyzm/ml/object.py", line 30, in __init__#012 import pyzm.ml.coral_edgetpu as tpu#012 File "/usr/local/lib/python3.8/dist-packages/pyzm/ml/coral_edgetpu.py", line 14, in <module>#012 from edgetpu.detection.engine import DetectionEngine#012ModuleNotFoundError: No module named 'edgetpu'#012]
asker
Post by asker » Wed Jan 06, 2021 2:19 am
You seem to be using an old version. The new stable versions use the new libraries.
And I just switched to the new model - It seems to be faster, but not sure it is any better
VicThor
Post by VicThor » Wed Jan 06, 2021 8:24 pm
Thanks asker, will give it a go.
VicThor
Post by VicThor » Thu Jan 07, 2021 11:55 pm
It seems to work much better than previous library and models.
However it creates way too many polygons for the same object.
asker
Post by asker » Sat Jan 09, 2021 12:00 pm
Can you post an example? I'm not seeing that issue of multiple polygons compared to the old model.
VicThor
Post by VicThor » Sat Jan 09, 2021 7:46 pm
Here is an example where not only wrongly detected but it's all over the place :D
https://i.postimg.cc/52zNv5vT/4-227763-0.jpg
asker
Post by asker » Sat Jan 09, 2021 10:04 pm
Can you link to the original image without the boxes so I can test?
VicThor
Post by VicThor » Sat Jan 09, 2021 10:44 pm
Thanks asker.
Here is the original:
https://i.postimg.cc/s266rLDZ/4-227763-101.jpg
asker
Post by asker » Sun Jan 10, 2021 12:32 am
This is an interesting one. You're right, the new model goes all over the place. Interestingly when I first ran it, it came out perfectly as a dog, but then I realized I had my config as:
a) First run TPU at 0.6 confidence
b) Then run YoloV4 at 0.3 confidence
So this filtered out all the boxes in your image.
I've realized, in my case, if I keep TPU threshold to 0.6, I do away with most of the useless things and I fallback to Yolov4 if TPU fails.
VicThor
Post by VicThor » Sun Jan 10, 2021 3:01 am
Thanks asker, that's really good. I will have to modify my objectconfig accordingly to the new way.
Is it possible you can put your config here? Or the important bits :)
Users browsing this forum: Magic919, suknil and 7 guests
