I'm using ZoneMinder since one year without any problem with 4 cameras;
But since some days I can't see the stream anymore on any camera.
My actual version is 1.34.20 and I think is an auto update because I never updated ZM.
The errors :
2020-09-24 00:40:15 web_php 3016 ERR Socket /var/run/zm/zms-484225s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.
Have you some ideas of the issue please2020-09-24 00:40:32 web_js 3016 ERR getStreamCmdResponse stream error: Socket /var/run/zm/zms-146540s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. - checkStreamForErrors()
Thx
