A trivial error on the Web GUI — missing item across the top menu bar
Greg_Talyor
Post by Greg_Talyor » Sat Sep 19, 2020 12:00 am
For an unprivileged user with the following settings, "Console" is missing from the menu bar at the top. Nevertheless, one still can access it by passing no parameters to index.php.
(Enabled, Stream, Events, Control, Monitors, Groups, System) = (Yes, View, View, None, None, None, None);
And to access "Console", the follows would work.
https://server/zm/index.php
or
https://server/zm/
A fix in a future version is very much welcomed. This error can be reproduced on v1.34.20. On the other hand, "Groups" should not be there.
Ta.
Re: A trivial error on the Web GUI — missing item across the top menu bar
Post by iconnor » Tue Sep 22, 2020 1:44 am
So... no permission to view monitors... so... can't view anything...
This is a bit stupid, but by all means, I will fix this for 1.34.22.
The console link will always be available. It will show no monitors.
