Zoneminder integration with Home Assistant [Solved]
pankaj13
Post by pankaj13 »
I have a Zoneminder (1.34) running and able to configure two cameras in it and can see live stream as well as record videos. I’d like to integrate Zoneminder with HA and added following items to my configuration.yaml.
zoneminder:
  - host: !secret zoneminder_host
    ssl: true
    verify_ssl: false
    username: !secret zoneminder_username
    password: !secret zoneminder_password
camera:
  - platform: zoneminder
After restarting, I see only a sensor for the Zoneminder and no signs of cameras.
Please advise where to look for signs of trouble as logs seems clean and show no error.
If anyone here has experience of integrating Zoneminder with Home Assistant please help me troubleshoot.
Thanks,
pankaj13
Re: Zoneminder integration with Home Assistant
Post by pankaj13 »
My ZM install is on a VM with Ubuntu 20.04 and ZM version 1.34, I tried another one with Ubuntu 18.04 and ZM 1.32. The configuration above works like a charm so solved the problem for now :D
pankaj13
Re: Zoneminder integration with Home Assistant [Solved]
Post by pankaj13 »
My bad, I forgot to update/close this thread :oops:
The issue was likely due to upgrading from 1.32 to 1.34 version, I did a fresh 1.34x install and everything worked fine.
Here is a snapshot of my configuration of ZM in Home Assistant.
zoneminder:
  - host: !secret zm_host
    ssl: true
    verify_ssl: false
    username: !secret zm_username
    password: !secret zm_password
switch:
    command_on: Modect
    command_off: Monitor
sensor:
    include_archived: true
    monitored_conditions: hour
camera:
