Can't add IP-camera Nobelic NBLC-2231F-ASD
nabludatel
Post by nabludatel »
Hi, all!
I have link which good working in other software (rtsp://username:password@192.168.10.50/cam/realmonitor?channel=1&subtype=0).
BUT it don'r work in ZoneMinder.
Am I applying the wrong settings? Help please.
5 cameras work
3 cameras dont work :(
Re: Can't add IP-camera Nobelic NBLC-2231F-ASD
nabludatel wrote: Sat Aug 08, 2020 11:35 am Hi, all!
5 cameras work
Are all your cams the same? If so you may be out of shared memory. Fix is to increase RAM or lower camera resolution.
Or, you may not be using a correct camera resolution in Zoneminder. A good check is to use VLC (Tools, Media Information, Codec) to check camera Display Resolution. Often the advertised cam resolution is different from what is actually used. And Zoneminder is picky.
nabludatel
Yes, you are right! I added RAM and it helped me.
