OK
this can also explain why the NinjaApp on my android phone doesn't work?
API doesn't work.HELP
Re: API doesn't work.HELP
Yes. If APIs don't work, zmNinja will not work
https://zmninja.readthedocs.io/en/lates ... g-api.html
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
I have a very very stupid qurstion
after I change the setting
do I need to restart the service or better reboot the pi?
AUTH_RELAY is set to hashed
A valid AUTH_HASH_SECRET is provided (not empty)
AUTH_HASH_IPS is disabled
OPT_USE_APIS is enabled
OPT_USE_GOOG_RECAPTCHA is disabled
It's sad to hear. I am using Ubuntu Bionic with Armbian Linux 4.19.69-meson64.
Which system is better to use in order to avoid problems?
