Deleting old events
RockUser
Deleting old events
Post by RockUser »
Hello all, I just need some help with setting up a filter that will auto delete old zoneminder events that are over 30 days old. I followed some threads on it but I must have messed something up with the date portion.
https://imgur.com/a/Y6CgFEf
For the date section after start date, I tried putting a number like "-30 days" like it says to in the FAQ
https://zoneminder.readthedocs.io/en/stable/faq.html
Purge By Age To delete events that are older than 7 days, create a new filter with “Date” set to “less than” and a value of “-7 days”, sort by “date/time” in “asc”ending order, then enable the checkbox “delete all matches”. You can also use a value of week or week and days: “-2 week” or “-2 week 4 day”
Doing this with "-30 days" just start deleting everything. So I was wondering if based on the screen shot if there's something obvious with my settings that I messed up.
I changed it to a specific date so that it would stop. But I originally had it at 30 days.
Re: Deleting old events
It is entirely possible that there is a bug. Turn on debug logging and let's see what the resulting sql is.
That being said, you should actually try to use Start Date/Time because it is more efficient and more tested.
Why is it more efficient? because the resulting SQL is to_days( E.StartTime ) instead of just using E.StartTime. WHich means it can't use the index on StartTime. So it iterates every event in the db (unless another index comes into play).
Here is a 30 day purge that has been working for me for a while:
RockUser
Post by RockUser »
bbunge wrote: Fri Jul 31, 2020 5:52 pm Here is a 30 day purge that has been working for me for a while:
This worked for me thank you for sharing. :D
iconnor wrote:That being said, you should actually try to use Start Date/Time because it is more efficient and more tested.
I will switch it to Date/Time then to save that extra bit of perfomance. Thank you for the advice. :D
