Running ZM 1.34.9, I no longer get the still images above the video events (e.g. on ZMNinja), and cant view stills on the ZM console either.
The video file plays fine, i've seen other posts referring to a similar error that states the video file doesn't exist, but I don't get that exact error.
When accessing footage from ZM Console and pressing "stills":
06/06/20 13:05:01.862250 web_php[351008].FAT [192.168.4.97] [Can't create frame images from video for this event 576082-video.mp4] at /usr/share/zoneminder/www/views/image.php line 213
06/06/20 13:05:02.961921 web_php[351038].ERR [192.168.4.97] [Capture file does not exist at /mnt/md0/events/3/2020-06-06/576082/00101-capture.jpg] at /usr/share/zoneminder/www/includes/Event.php line 424
When opening event n ZmNinja:
06/06/20 12:41:35.626663 web_php[350624].FAT [192.168.4.51] [Can't create frame images from video for this event 576045-video.mp4] at /usr/share/zoneminder/www/views/image.php line 213
[Sat Jun 06 13:04:58.634227 2020] [php7:notice] [pid 351008] [client 192.168.4.97:49386] PHP Notice: Undefined index: Delta in /usr/share/zoneminder/www/includes/Event.php on line 409, referer: https://XXXXX/zm/index.php?view=event&eid=576082&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=StartDateTime&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3E%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=-1+hour&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bval%5D=3&sort_field=StartTime&sort_asc=1&page=1
ffmpeg version 4.2.2-1+b1 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 9 (Debian 9.2.1-28)
configuration: --prefix=/usr --extra-version=1+b1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 31.100 / 56. 31.100
libavcodec 58. 54.100 / 58. 54.100
libavformat 58. 29.100 / 58. 29.100
libavdevice 58. 8.100 / 58. 8.100
libavfilter 7. 57.100 / 7. 57.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 5.100 / 5. 5.100
libswresample 3. 5.100 / 3. 5.100
libpostproc 55. 5.100 / 55. 5.100
Invalid duration specification for ss: -i
sh: 1: -ss: not found
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/mnt/md0/events/3/2020-06-06/576082/576082-video.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
title : Zoneminder Security Recording
encoder : Lavf58.29.100
Duration: 00:09:59.81, start: 0.000000, bitrate: 5644 kb/s
Stream #0:0(und): Video: h264 (Baseline) (avc1 / 0x31637661), yuvj420p(pc, bt709), 2048x2048, 5610 kb/s, 10 fps, 10 tbr, 90k tbn, 180k tbc (default)
Metadata:
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 8000 Hz, mono, fltp, 32 kb/s (default)
Metadata:
handler_name : SoundHandler
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> mjpeg (native))
Press [q] to stop, [?] for help
Output #0, image2, to '/mnt/md0/events/3/2020-06-06/576082/00100-capture.jpg':
Metadata:
major_brand : isom
minor_version : 512
Stream #0:0(und): Video: mjpeg, yuvj420p(pc), 2048x2048, q=2-31, 200 kb/s, 10 fps, 10 tbn, 10 tbc (default)
Metadata:
encoder : Lavc58.54.100 mjpeg
Side data:
cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: -1
frame= 1 fps=0.0 q=9.8 Lsize=N/A time=00:00:00.10 bitrate=N/A speed=0.404x
video:240kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Anyone know what could be causing this error? The video file is present and plays OK, just no stills.
Cheers!
