root@vserver:/home/jimmy# systemctl start zoneminder
Job for zoneminder.service failed because the control process exited with error code.
See "systemctl status zoneminder.service" and "journalctl -xe" for details.
root@vserver:/home/jimmy# systemctl status zoneminder.service
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2020-06-03 09:32:07 EDT; 1s ago
Process: 1581 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=1/FAILURE)
root@vserver:/home/jimmy# journalctl -xe
-- A start job for unit zoneminder.service has begun execution.
-- The job identifier is 2794.
Jun 03 09:32:17 vserver zmpkg[1598]: INF [Sanity checking States table...]
Jun 03 09:32:17 vserver zmpkg[1598]: INF [Command: start]
Jun 03 09:32:17 vserver su[1606]: (to www-data) root on none
Jun 03 09:32:17 vserver su[1606]: pam_unix(su:session): session opened for user www-data by (uid=0)
Jun 03 09:32:17 vserver systemd[1]: Started Session c17 of user www-data.
-- Subject: A start job for unit session-c17.scope has finished successfully
-- Defined-By: systemd
-- Support: https://www.debian.org/support--
-- A start job for unit session-c17.scope has finished successfully.
-- The job identifier is 2875.
Jun 03 09:32:17 vserver su[1606]: pam_unix(su:session): session closed for user www-data
Jun 03 09:32:17 vserver su[1609]: (to www-data) root on none
Jun 03 09:32:17 vserver su[1609]: pam_unix(su:session): session opened for user www-data by (uid=0)
Jun 03 09:32:17 vserver systemd[1]: Started Session c18 of user www-data.
-- Subject: A start job for unit session-c18.scope has finished successfully
-- A start job for unit session-c18.scope has finished successfully.
-- The job identifier is 2960.
Jun 03 09:32:17 vserver systemd[1]: session-c17.scope: Succeeded.
-- Subject: Unit succeeded
-- The unit session-c17.scope has successfully entered the 'dead' state.
Jun 03 09:32:17 vserver su[1609]: pam_unix(su:session): session closed for user www-data
Jun 03 09:32:17 vserver systemd[1]: session-c18.scope: Succeeded.
-- The unit session-c18.scope has successfully entered the 'dead' state.
Jun 03 09:32:17 vserver systemd[1]: zoneminder.service: Control process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- An ExecStart= process belonging to unit zoneminder.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Jun 03 09:32:17 vserver systemd[1]: zoneminder.service: Failed with result 'exit-code'.
root@vserver:/usr/bin# zmpkg.pl version
1.34.15
root@vserver:/usr/bin# zmpkg.pl start
06/03/2020 09:55:16.513465 zmpkg[795].INF [main:310] [Sanity checking States table...]
06/03/2020 09:55:16.566363 zmpkg[795].INF [main:95] [Command: start]
06/03/2020 09:55:16.725896 zmsystemctl[801].INF [main:71] [Redirecting command through systemctl]
Job for zoneminder.service failed because the service did not take the steps required by its unit configuration.
root@vserver:/var/log/zm# cat ./zmpkg.log
06/03/2020 09:55:16.788538 zmpkg[812].INF [main:310] [Sanity checking States table...]
06/03/2020 09:55:16.790249 zmpkg[812].INF [main:95] [Command: start]
06/03/2020 09:55:18.186586 zmpkg[812].INF [main:203] [Single server configuration detected. Starting up services.]
06/03/2020 09:55:28.825673 zmpkg[926].INF [main:310] [Sanity checking States table...]
06/03/2020 09:55:28.827276 zmpkg[926].INF [main:95] [Command: start]
06/03/2020 09:55:39.071546 zmpkg[941].INF [main:310] [Sanity checking States table...]
06/03/2020 09:55:39.074625 zmpkg[941].INF [main:95] [Command: start]
.... over and over and over....
