Update ZoneMinder problem
sstars
Post by sstars » Mon Jun 01, 2020 7:41 am
Please help...
Ubuntu 18.04.4
After updating ZoneMinder I have an error:
ersion mismatch, system is version 1.34.15, database is 1.32.3.
Please run zmupdate.pl to update
When I try to run zmupdate.pl have this :
Initiating database upgrade to version 1.34.15 from version 1.32.3
Please ensure that ZoneMinder is stopped on your system prior to upgrading the database.
Press enter to continue or ctrl-C to stop :
Do you wish to take a backup of your database prior to upgrading?
This may result in a large file in /tmp/zm if you have a lot of events.
Press 'y' for a backup or 'n' to continue : y
Creating backup to /tmp/zm/zm-1.32.3.dump. This may take several minutes.
mysqldump: [Warning] Using a password on the command line interface can be insecure.
Please, have any idea???
sstars
Re: Update ZoneMinder problem
Post by sstars » Tue Jun 02, 2020 10:57 am
Problem solved, after restarting server several times and run sudo zmupdate.pl SQL was updated and now working properly.
burger
Post by burger » Fri Jun 05, 2020 3:08 am
SQL updates can take a while. Monitor process with top/htop.
fastest way to test streams:
ffmpeg -i rtsp://<ipaddress>:554/path output.mp4
from terminal, and run through paths on ispydb or in zm hcl
