jpeg errors
mad1524
jpeg errors
Post by mad1524 »
Version of ZoneMinder 1.34
name and version of OS - ubuntu server 18.04
I tried to connect IP cameras - it did not work, there were some strange errors.
then I put the server and Zoneminder from scratch. I started to add trying on wifi android and iphone.
The iPhone shows in green, but a very bad image, blurry and almost invisible.
an old android does not connect at all (although it worked fine on the local server and the image quality was not bad).
The logs are as follows:
held buffer is undersized for requested buffer
failed requesting writeable buffer for reading JPEG image
unable to decode jpeg
I came across this program for the first time, but it is very necessary to configure everything qualitatively. Help me please.
log
log
burger
Re: jpeg errors
Post by burger »
Please provide more information (screenshots): Camera settings in ZM, camera type and program running.
Also see:
https://wiki.zoneminder.com/Android
https://wiki.zoneminder.com/Finding_Camera_Stream_Paths
Camera / app may just not be compatible.
fastest way to test streams:
mad1524
Re: jpeg errors
Post by mad1524 »
thanks. I'll try to figure out what's on the links and if it doesn't work, of course I'll provide more information.
