Timeline shows just 1 frame / event
Henri
Post by Henri » Fri May 08, 2020 12:08 pm
My configuration is ZM 1.34.11 running on Ubuntu 18.04
If i start timeline view for several (recording) events on one Monitor the Mouseover on the timeline shows just one frame per event.
That means if my event section lengt is 3 minutes the picture changes just every 3 timeline minutes on not as in 1.32.3 where i can see several pictures/frames during the timeline mouseover.
This makes the timeline useless because you can not find out what happens inside an event, specialy if your section lengt is high (10 minutes or more).
Henri
Re: Timeline shows just 1 frame / event
Post by Henri » Sun May 10, 2020 12:17 pm
Is there someone else with the same problem or is nobody using the timeline feature.
td
Post by td » Tue Nov 17, 2020 10:57 pm
Hello Henri,
same with me, version 1.34.21.
When hovering the mouse ove the timeline exactly one image is displayed. When hovering further the displayed image does not change.
Best
td
Users browsing this forum: No registered users and 8 guests
