Constant popup update reminders - ZoneMinder 1.34.6
remembermyname2000
Post by remembermyname2000 »
Greetings,
Recently, I did a fresh install of Zoneminder 1.34.6 on FreeBSD 12.1 but once I got it started there has been a popup constantly coming up with the following message:
An update to ZoneMinder is available.
The latest release is v1.34.8, you have v1.34.6.
No matter what I set it to, 'Remind my in 1 hour', or 1 day to 'Don't remind me', the popups continue about every minute. Any advise on how to correct this issue?
I did however, stop ZoneMinder and ran zmupdate.pl and it states that I'm already running 1.34.6 . :?
The ZoneMinder install itself was installed from ports if that is any help.
BlackAndChrome
Re: Constant popup update reminders - ZoneMinder 1.34.6
Post by BlackAndChrome »
Same here on CentOS 7. I was getting the pop-up on 1.34.4 so I updated but RPMFusion took me to 1.34.6 and no new updates are available.
-Nick
harry491
Post by harry491 »
I followed the suggestion to stop ZoneMinder and ran zmupdate.pl with following result
Database already at version 1.34.5, update skipped
OS is Debian, Version 1.34.5 installed just 1 week ago using the suggested depository.
I tried "apt update" --> nothing to update
Installed version of zoneminder components are
zonemaster-cli/stable 1.0.5-1 all
zoneminder-dbg/buster 1.34.5-buster1 amd64
zoneminder-dbg/buster 1.34.6-buster1 armhf <----- ???? why is an arm code in here
zoneminder-doc/buster,now 1.34.6-buster1 all [installed,automatic]
zoneminder/buster,now 1.34.5-buster1 amd64 [installed]
zoneminder/buster 1.34.6-buster1 armhf <----- ???? why is an arm code in here
OS: Linux zm 4.19.0-8-amd64 #1 SMP Debian 4.19.98-1 (2020-01-26) x86_64 GNU/Linux
How to continue?
Greetings
Harry491
I'll have to double check the code that stores your selection for when to remind you next.
In the meantime, just turn off checking for updates under Options->System->CHECK_FOR_UPDATES
I found the problem. I will release 1.34.9 today with the fix.
