Ive recently setup ZoneMinder and have added a monitor to which I can see the stream using a web browser or VLC etc. If I try and add the camera to my ZoneMinder installation I get "Monitor Not Capturing" within the console. The camera is a Hikvision and should work based on the documentation - here is the log
2020-03-05 09:40:20.821690 zmwatch[53345].WAR-zmwatch.pl [Restarting capture daemon for Cam1-Yard, no image since startup. Startup time was 1583401207 - now 1583401220 > 5]
2020-03-05 09:40:19.745392 web_js[52944].ERR-?view=log [Export request failed: 500 / Internal Server Error - exportFail()]
2020-03-05 09:40:17.079620 zmdc[53287].ERR-zmdc.pl ['zmc -m 1' exited abnormally, exit status 255]
2020-03-05 09:40:17.066223 zmc_m1[55647].FAT-zm_remote_camera_rtsp.cpp/158 [No RTSP sources]
2020-03-05 09:40:07.055881 zmc_m1[55647].INF-zmc.cpp/223 [Starting Capture version 1.34.5]
2020-03-05 09:40:06.950614 zmc_m1[55648].ERR-zm_rtsp.cpp/256 [Recv failed; Connection reset by peer]
2020-03-05 09:40:06.942694 zmc_m1[55647].INF-zm_ffmpeg.cpp/84 [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor is not part of your debug targets]
2020-03-05 09:40:06.841940 zmdc[55647].INF-zmdc.pl ['zmc -m 1' started at 20/03/05 09:40:06]
2020-03-05 09:40:06.841930 zmdc[53287].INF-zmdc.pl ['zmc -m 1' starting at 20/03/05 09:40:06, pid = 55647]
2020-03-05 09:40:06.836420 zmdc[53287].INF-zmdc.pl [Starting pending process, zmc -m 1]
2020-03-05 09:40:01.829810 zmdc[53287].ERR-zmdc.pl ['zmc -m 1' exited abnormally, exit status 255]
2020-03-05 09:40:01.815201 zmc_m1[55643].FAT-zm_remote_camera_rtsp.cpp/158 [No RTSP sources]
2020-03-05 09:40:00.813130 zmdc[53287].INF-zmdc.pl ['zmc -m 1' sending stop to pid 55643 at 20/03/05 09:40:00]
2020-03-05 09:40:00.582870 zmwatch[53345].WAR-zmwatch.pl [Restarting capture daemon for Cam1-Yard, no image since startup. Startup time was 1583401191 - now 1583401200 > 5]
2020-03-05 09:39:51.817842 zmc_m1[55643].INF-zmc.cpp/223 [Starting Capture version 1.34.5]
2020-03-05 09:39:51.708721 zmc_m1[55644].ERR-zm_rtsp.cpp/256 [Recv failed; Connection reset by peer]
2020-03-05 09:39:51.699587 zmc_m1[55643].INF-zm_ffmpeg.cpp/84 [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor is not part of your debug targets]
2020-03-05 09:39:51.595290 zmdc[55643].INF-zmdc.pl ['zmc -m 1' started at 20/03/05 09:39:51]
2020-03-05 09:39:51.595280 zmdc[53287].INF-zmdc.pl ['zmc -m 1' starting at 20/03/05 09:39:51, pid = 55643]
2020-03-05 09:39:51.589700 zmdc[53287].INF-zmdc.pl [Starting pending process, zmc -m 1]
2020-03-05 09:39:50.587680 zmdc[53287].ERR-zmdc.pl ['zmc -m 1' exited abnormally, exit status 255]
2020-03-05 09:39:50.577993 zmc_m1[55637].FAT-zm_remote_camera_rtsp.cpp/158 [No RTSP sources]
2020-03-05 09:39:50.577230 zmdc[53287].INF-zmdc.pl ['zmc -m 1' sending stop to pid 55637 at 20/03/05 09:39:50]
2020-03-05 09:39:50.355250 zmwatch[53345].WAR-zmwatch.pl [Restarting capture daemon for Cam1-Yard, no image since startup. Startup time was 1583401180 - now 1583401190 > 5]
2020-03-05 09:39:40.572305 zmc_m1[55637].INF-zmc.cpp/223 [Starting Capture version 1.34.5]
2020-03-05 09:39:40.459451 zmc_m1[55638].ERR-zm_rtsp.cpp/256 [Recv failed; Connection reset by peer]
2020-03-05 09:39:40.452582 zmc_m1[55637].INF-zm_ffmpeg.cpp/84 [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor is not part of your debug targets]
2020-03-05 09:39:40.346150 zmdc[55637].INF-zmdc.pl ['zmc -m 1' started at 20/03/05 09:39:40]
2020-03-05 09:39:40.346140 zmdc[53287].INF-zmdc.pl ['zmc -m 1' starting at 20/03/05 09:39:40, pid = 55637]
2020-03-05 09:39:40.340560 zmdc[53287].INF-zmdc.pl [Command 'zmc -m 1' removed from pending list at 20/03/05 09:39:40]
2020-03-05 09:39:40.096310 zmwatch[53345].WAR-zmwatch.pl [Restarting capture daemon for Cam1-Yard, no image since startup. Startup time was 1583401166 - now 1583401180 > 5]
2020-03-05 09:39:36.366990 zmdc[53287].ERR-zmdc.pl ['zmc -m 1' exited abnormally, exit status 255]
2020-03-05 09:39:36.353010 zmc_m1[55633].FAT-zm_remote_camera_rtsp.cpp/158 [No RTSP sources]
2020-03-05 09:39:26.342741 zmc_m1[55633].INF-zmc.cpp/223 [Starting Capture version 1.34.5]
2020-03-05 09:39:26.245723 zmc_m1[55634].ERR-zm_rtsp.cpp/256 [Recv failed; Connection reset by peer]
2020-03-05 09:39:26.236499 zmc_m1[55633].INF-zm_ffmpeg.cpp/84 [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor is not part of your debug targets]
