pollution
Posts: 9 Joined: Mon Jul 15, 2019 7:42 am
Post
by pollution » Mon Mar 02, 2020 1:19 pm
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Got signal 11 (Segmentation fault), crashing]
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Signal address is 0x18, from 0x56313f844097]
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Backtrace 0: /usr/bin/zmc(_Z14zm_die_handleriP9siginfo_tPv+0x59) [0x56313f7bf319]]
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Backtrace 1: /lib64/libpthread.so.0(+0x12130) [0x7fb8b75aa130]]
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Backtrace 2: /usr/bin/zmc(_ZN10VideoStoreC1EPKcS1_P8AVStreamS3_P7Monitor+0x1067) [0x56313f844097]]
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Backtrace 3: /usr/bin/zmc(_ZN12FfmpegCamera16CaptureAndRecordER5Image7timevalPc+0x5b4) [0x56313f801f04]]
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Backtrace 4: /usr/bin/zmc(_ZN7Monitor7CaptureEv+0x1a9) [0x56313f7854c9]]
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Backtrace 5: /usr/bin/zmc(main+0x988) [0x56313f75ecc8]]
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Backtrace 6: /lib64/libc.so.6(__libc_start_main+0xeb) [0x7fb8b5682bab]]
Mar 2 16:18:54 root zmc_m30[17113]: ERR [zmc_m30] [Backtrace 7: /usr/bin/zmc(_start+0x2a) [0x56313f760bba]]
Mar 2 16:18:54 root zmdc[11750]: ERR ['zmc -m 30' exited abnormally, exit status 11]
pollution
Post
by pollution » Mon Mar 02, 2020 3:37 pm
1.34.5 not working
1.32.3 not building
Installing /var/tmp/portage/www-misc/zoneminder-1.32.3-r1/work/zoneminder-1.32.3_build/onvif/proxy/output/usr/share/man/man3/ONVIF::Analytics::Types::Space2DDescription.3pm
Installing /var/tmp/portage/www-misc/zoneminder-1.32.3-r1/work/zoneminder-1.32.3_build/onvif/proxy/output/usr/share/man/man3/ONVIF::Device::Types::OSDTextConfiguration.3pm
Installing /var/tmp/portage/www-misc/zoneminder-1.32.3-r1/work/zoneminder-1.32.3_build/onvif/proxy/output/usr/share/man/man3/WSNotification::Elements::ProblemAction.3pm
make[3]: Leaving directory '/var/tmp/portage/www-misc/zoneminder-1.32.3-r1/work/zoneminder-1.32.3_build/onvif/proxy'
make[2]: Leaving directory '/var/tmp/portage/www-misc/zoneminder-1.32.3-r1/work/zoneminder-1.32.3_build'
[ 21%] Built target zmonvifproxy
make[1]: Leaving directory '/var/tmp/portage/www-misc/zoneminder-1.32.3-r1/work/zoneminder-1.32.3_build'
make: *** [Makefile:130: all] Error 2
* ERROR: www-misc/zoneminder-1.32.3-r1::oubliette failed (compile phase):
* emake failed
* If you need support, post the output of `emerge --info '=www-misc/zoneminder-1.32.3-r1::oubliette'`,
* the complete build log and the output of `emerge -pqv '=www-misc/zoneminder-1.32.3-r1::oubliette'`.
* The complete build log is located at '/var/tmp/portage/www-misc/zoneminder-1.32.3-r1/temp/build.log'.
* The ebuild environment file is located at '/var/tmp/portage/www-misc/zoneminder-1.32.3-r1/temp/environment'.
* Working directory: '/var/tmp/portage/www-misc/zoneminder-1.32.3-r1/work/zoneminder-1.32.3_build'
* S: '/var/tmp/portage/www-misc/zoneminder-1.32.3-r1/work/zoneminder-1.32.3'
plz help!
Bluemax
Posts: 121 Joined: Wed Jun 12, 2019 5:15 pm
Post
by Bluemax » Mon Mar 02, 2020 5:57 pm
That rather looks like an individual system problem. You probably have to contact your linux distribution maintainer.
Posts: 2900 Joined: Fri Oct 29, 2010 1:43 am
Post
by iconnor » Mon Mar 02, 2020 6:53 pm
So this is what.... freebsd? How about which version of ffmpeg libs are you building against?
pollution
Post
by pollution » Tue Mar 03, 2020 6:23 am
Its Gentoo. ffmpeg was 4.1.3, i try to build 4.2.2, same problem.
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Got signal 11 (Segmentation fault), crashing]
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Signal address is (nil), from 0x55d46015a097]
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Backtrace 0: /usr/bin/zmc(_Z14zm_die_handleriP9siginfo_tPv+0x59) [0x55d4600d5319]]
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Backtrace 1: /lib64/libpthread.so.0(+0x12130) [0x7f809941a130]]
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Backtrace 2: /usr/bin/zmc(_ZN10VideoStoreC1EPKcS1_P8AVStreamS3_P7Monitor+0x1067) [0x55d46015a097]]
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Backtrace 3: /usr/bin/zmc(_ZN12FfmpegCamera16CaptureAndRecordER5Image7timevalPc+0x5b4) [0x55d460117f04]]
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Backtrace 4: /usr/bin/zmc(_ZN7Monitor7CaptureEv+0x1a9) [0x55d46009b4c9]]
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Backtrace 5: /usr/bin/zmc(main+0x988) [0x55d460074cc8]]
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Backtrace 6: /lib64/libc.so.6(__libc_start_main+0xeb) [0x7f80973ffbab]]
Mar 3 09:21:32 root zmc_m12[12140]: ERR [zmc_m12] [Backtrace 7: /usr/bin/zmc(_start+0x2a) [0x55d460076bba]]
Mar 3 09:21:32 root zmdc[10221]: ERR ['zmc -m 12' exited abnormally, exit status 11]
This system run 1.32.2 without errors.
pollution
Post
by pollution » Tue Mar 03, 2020 6:31 am
I change "Source Type" on my cameras from "Ffmpeg" to "Remote" and it seems its no errors anymore. Will watch. Thank you!
pollution
Post
by pollution » Tue Mar 03, 2020 9:07 am
Source Type Remote cant record h264 passthrough video. Then I use x264 encode option its take to much CPU (LA ~130! for my 30 cameras). I switched to write jpgs, but its also takes much more CPU and disk space. Plz help me return to ffmpeg source type without segfaults.
pollution
Post
by pollution » Tue Mar 03, 2020 9:14 am
Got this errors
Mar 3 12:12:43 root zmc_m12[5330]: FAT [zmc_m12] [Could not find encoder for 'unknown_codec']
Mar 3 12:13:55 root zma_m12[8505]: ERR [zma_m12] [Shared data not initialised by capture daemon for monitor vhod]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Got signal 11 (Segmentation fault), crashing]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Signal address is 0x18, from 0x55fdc37f2337]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Backtrace 0: /usr/bin/zmc(_Z14zm_die_handleriP9siginfo_tPv+0x59) [0x55fdc3762769]]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Backtrace 1: /lib64/libpthread.so.0(+0x12130) [0x7f0183760130]]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Backtrace 2: /usr/bin/zmc(_ZN10VideoStoreC1EPKcS1_P8AVStreamS3_P7Monitor+0x1067) [0x55fdc37f2337]]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Backtrace 3: /usr/bin/zmc(_ZN12FfmpegCamera16CaptureAndRecordER5Image7timevalPc+0x5b4) [0x55fdc37acd64]]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Backtrace 4: /usr/bin/zmc(_ZN7Monitor7CaptureEv+0x1a9) [0x55fdc3728919]]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Backtrace 5: /usr/bin/zmc(main+0x988) [0x55fdc37020e8]]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Backtrace 6: /lib64/libc.so.6(__libc_start_main+0xeb) [0x7f0181470bab]]
Mar 3 12:14:04 root zmc_m12[8500]: ERR [zmc_m12] [Backtrace 7: /usr/bin/zmc(_start+0x2a) [0x55fdc370400a]]
pollution
Post
by pollution » Tue Mar 03, 2020 10:09 am
Well, it was gentoo specific problem, not a bug. Rebuilding ffmpeg with additional use flags fix this errors. Now all work fine.
