error in systemctl status zoneminder
rony787
Post by rony787 »
I upgraded to 1.34.X version and am still getting the same error in systemctl status zoneminder.
[root@zoneminder zoneminder]# systemctl status zoneminder
● zoneminder.service - ZoneMinder CCTV recording and security system
Loaded: loaded (/usr/lib/systemd/system/zoneminder.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/zoneminder.service.d
└─zm-httpd.conf
Active: active (running) since Mon 2019-11-04 22:30:06 CST; 5s ago
Process: 6983 ExecStop=/usr/bin/zmpkg.pl stop (code=exited, status=0/SUCCESS)
Process: 6999 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
Main PID: 7014 (zmdc.pl)
CGroup: /system.slice/zoneminder.service
├─7014 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
├─7044 /usr/bin/zmc -m 2
├─7063 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
├─7066 /usr/bin/zma -m 2
├─7078 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
├─7091 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
├─7103 /usr/bin/perl -wT /usr/bin/zmwatch.pl
├─7116 /usr/bin/perl -wT /usr/bin/zmtelemetry.pl
└─7126 /usr/bin/perl -wT /usr/bin/zmstats.pl
Nov 04 22:30:05 zoneminder zmfilter_2[7078]: INF [Scanning for events using filter id '2']
Nov 04 22:30:05 zoneminder zmdc[7014]: INF ['zmwatch.pl' starting at 19/11/04 22:30:05, pid = 7103]
Nov 04 22:30:05 zoneminder zmdc[7103]: INF ['zmwatch.pl' started at 19/11/04 22:30:05]
Nov 04 22:30:06 zoneminder zmwatch[7103]: INF [Watchdog starting, pausing for 30 seconds]
Nov 04 22:30:06 zoneminder zmdc[7116]: INF ['zmtelemetry.pl' started at 19/11/04 22:30:06]
Nov 04 22:30:06 zoneminder zmdc[7014]: INF ['zmtelemetry.pl' starting at 19/11/04 22:30:06, pid = 7116]
Nov 04 22:30:06 zoneminder zmdc[7014]: INF ['zmstats.pl' starting at 19/11/04 22:30:06, pid = 7126]
Nov 04 22:30:06 zoneminder. zmdc[7126]: INF ['zmstats.pl' started at 19/11/04 22:30:06]
Nov 04 22:30:06 zoneminder systemd[1]: Started ZoneMinder CCTV recording and security system.
Nov 04 22:30:06 zoneminder zmstats[7126]: INF [Stats Daemon starting in 30 seconds]
[root@zoneminder zoneminder]# ls -arlt
total 4
drwxrwxrwx. 2 apache apache 6 Nov 2 23:17 .
drwxr-xr-x. 11 root root 4096 Nov 3 03:26 ..
[root@zoneminder zoneminder]# rpm -qa |grep zoneminder
zoneminder-common-1.33.14-1.495.20191103gitg4e16e9052.el7.x86_64
zoneminder-1.33.14-1.495.20191103gitg4e16e9052.el7.x86_64
zoneminder-httpd-1.33.14-1.495.20191103gitg4e16e9052.el7.x86_64
There are no logs in /var/log/zoneminder.
lbm
Re: error in systemctl status zoneminder
Post by lbm »
Which errors exactly ?..
And FYI.. According to your output, you are still running 1.33. :)
