Ubuntu Install for 1.34.x
Post by bbunge » Fri Jan 17, 2020 5:51 pm
Install procedures Trusty, Xenial, Bionic and Eoan done. (Bionic and Eoan can use the same install script!). Disco support ends January 2020 so it is not included. Bionic LEMP (NGINX) also included
See: https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.34.x
Edit 1117 19JAN20
Re: Ubuntu Install for 1.34.x
Post by iconnor » Fri Jan 17, 2020 6:09 pm
I am working on the ppa, have to build mp4v2 for disco and eoan. Alternatively people can use https://zmrepo.zoneminder.com for ubuntu packages too.
In general terms, the install should be the same for 1.34 as for 1.32.
apbb2
Post by apbb2 » Fri Jan 17, 2020 8:37 pm
Can anyone verify that an in place upgrade worked with no issues from 1.32?
Thank you
Post by bbunge » Fri Jan 17, 2020 8:40 pm
Thank you
Stay tuned. It is on my list to test.
apbb2
Post by apbb2 » Fri Jan 17, 2020 8:42 pm
Thank you
Thank you as alway bbunge. You are all much appreciated.
Post by iconnor » Fri Jan 17, 2020 8:58 pm
If someone is running a master snapshot it seems to feel that 1.33.16~202001171236 is a higher number than 1.34.0, so you may have to actually grab the .deb from the ppa and install it manually. Or remove zoneminder, remove the old ppa then re-install.
Post by bbunge » Fri Jan 17, 2020 9:44 pm
Just did an upgrade on a Bionic server running ZM 1.33.16 from the zoneminder-master PPA. Before I changed the PPA I ran an apt update/apt upgrade as the server had been powered down for a week. Much to my surprise Zoneminder upgraded to the 1.34. version in the zoneminder-master PPA. So, I removed the zoneminder-master (add-apt-repository --remove ppa:iconnor/zoneminder-master) and added zoneminder-1.34 (add-apt-repository ppa:iconnor/zoneminder-1.34) then apt-upgrade. The upgrade ran the install for Zoneminder 1.34.0 and all is well!
Sigge
Post by Sigge » Sat Jan 18, 2020 1:42 pm
On Ubuntu Server 18.04 and Zoneminder 1.32.3.
Did:
sudo add-apt-repository ppa:iconnor/zoneminder-1.34
sudo apt-get update && sudo apt-get full-upgrade
sudo add-apt-repository --remove ppa:iconnor/zoneminder-1.32
and all worked fine!
Thanks!
Post by bbunge » Sun Jan 19, 2020 4:22 pm
While I am not too familiar with NGINX I was pleasantly surprised with how quickly Zoneminder 1.34.0 works with a LEMP setup! I ran the install on my test server with just two cameras.
See https://wiki.zoneminder.com/Ubuntu_Serv ... .2C_PHP.29
Harold Marshall
Post by Harold Marshall » Sun Jan 19, 2020 4:49 pm
Running ZoneMinder for the first time ever, trying to get totally rid of Windows finally (long history with commercial DVRs & VMSs). 1.34 seems to work great on Ubuntu 19.10.
One camera seems to disconnect and reconnect intermittently. The cam is branded as "FINE". Does anyone have any experience with those?
BR,
Harold
Post by bbunge » Wed Jan 22, 2020 2:54 pm
A word of caution for upgraders. As of 22JAN20 the PPA/zoneminder-master, the development area, has versions of Zoneminder 1.34. If you were using the 1.33.x development version of Zoneminder and you apt update - apt upgrade without changing to PPA/zoneminder-1.34 you will get the next development version. Just be aware that it is possible some things may not work!
Post by bbunge » Thu Jan 23, 2020 7:27 pm
For those of you using MySQL 8 on Ubuntu 19.10, there are some additional MySQL configurations that have to be done.
See: https://wiki.zoneminder.com/Ubuntu_Serv ... yond.3F.29
Be advised that there is at least one procedure posted on a couple of sites that has steps to do this that are not needed...
apbb2
Post by apbb2 » Thu Jan 23, 2020 8:39 pm
Did:
Thanks!
SO I built a 16.04 machine with ZM 1.32.3 & successfully upgraded to 1.34 & then upgraded to 18.04.
Some PHP hiccup that was easily resolvable with the help of this forum & the search bar.
Now on to my installs in a couple of weeks time when I have a chance.
Thanks again to all. You have made my job much easier.
MoOz
Post by MoOz » Sat Jan 25, 2020 2:01 am
clean install on Ubuntu 18.04
This is my script
#!/bin/sh
clear
read -p "This script installs Apache2, Mariadb Server, PHP and Zoneminder 1.32.3 with MP4 support on Ubuntu 19.04 AMD64.
Press Enter to continue or Ctrl + c to quit" nothin g
clear
read -p "You must be logged in as root using sudo su ...
Press Enter to continue or Ctrl + c to quit" nothing
clear
apt -y install apache2 php mariadb-server php-mysql libapache2-mod-php7.2 x264 x265 gdebi
clear
read -p "Next secure MySQL server by entering requested information. Press enter to continue" nothing
mysql_secure_installation
clear
read -p "Next we will download the libmp4v2 package and install it.
wget -O /tmp/libmp4v2-2_2.0-1_amd64.deb --no-check-certificate "https://onedrive.live.com/download?cid= ... HH6TkX22R8"
apt -y install /tmp/libmp4v2-2_2.0-1_amd64.deb
clear
read -p "Next we will add the PPA repository, install and configure the system to run Zoneminder.
apt install -y software-properties-common
clear
clear
apt install -y zoneminder
systemctl enable zoneminder
service zoneminder start
adduser www-data video
a2enconf zoneminder
a2enmod rewrite
service apache2 reload
clear
read -p "Install complete. Open Zoneminder/Options and set the timezine. Press enter to continue" nothing
clear
works 1st go
fix Date time
Post by bbunge » Sat Jan 25, 2020 12:48 pm
This is my script
#!/bin/sh
clear
clear
clear
clear
clear
clear
clear
clearv2
a2enconf zoneminder
a2enmod rewrite
clear
clear
works 1st go
fix Date time
Besides a couple of typos you do not need gdebi, x264, x265 or libmp4v2
Users browsing this forum: Magic919 and 7 guests
