I get an error when starting zoneminder:
root@zoneminder-be:~# systemctl start zoneminder
Job for zoneminder.service failed because the control process exited with error code.
See "systemctl status zoneminder.service" and "journalctl -xe" for details.
root@zoneminder-be:~# systemctl status zoneminder.service
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Thu 2021-04-08 17:26:16 PDT; 4s ago
Process: 4675 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=1/FAILURE)
root@zoneminder-be:~# ps axuw | grep zm
www-data 3170 0.0 0.2 33936 16520 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
www-data 3200 0.0 0.4 49092 35508 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
www-data 3207 0.0 0.4 49096 35488 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
www-data 3215 0.0 0.2 33412 19676 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmwatch.pl
www-data 3222 0.0 0.4 54080 40256 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmupdate.pl -c
www-data 3228 0.0 0.2 33192 19536 ? S 17:11 0:00 /usr/bin/perl -wT /usr/bin/zmstats.pl
root 4944 0.0 0.0 6076 884 pts/0 R+ 17:29 0:00 grep zm
