Recording on the fly?
BobLaske
Post by BobLaske » Wed Jun 24, 2020 3:07 am
While I am watching a monitor/camera, is there a way to start and stop a recording of what I'm seeing? I thought I did that once but cannot find anything about it online or looking at the app.
Re: Recording on the fly?
Post by iconnor » Wed Jun 24, 2020 3:56 pm
There should be a force alarm button on the right...
BobLaske
Post by BobLaske » Wed Jun 24, 2020 4:15 pm
Of course, it's right in my face :).
Maybe it should say 'Force alarm/record'
Thank you for replying, I'll try it out.
BobLaske
Post by BobLaske » Wed Jun 24, 2020 4:18 pm
Oh, one more question please. After I cancel the alarm, how do I download that video? I don't see it anywhere.
BobLaske
Post by BobLaske » Fri Jun 26, 2020 6:05 pm
Hi, does anyone know where the saved recordings are? I don't see it in the dashboard.
Post by iconnor » Fri Jun 26, 2020 11:48 pm
It should be listed if you click in the Hour column on the console. Or in the live view at the bottom should be a constantly updated list of events.
The first thing you need to do is update to 1.34.
1.33 was a development version. Who knows what works or doesn't work in it.
BobLaske
Post by BobLaske » Sat Jun 27, 2020 12:12 am
I agree, I need to update. I've been fearing disruptions from doing that. Maybe there's a way to save the entire config and import it into a replacement server. I'll check it out.
Thanks for the help on the above. I'll take another look.
BobLaske
Post by BobLaske » Sat Jun 27, 2020 12:16 am
Oops, mine is actually 1.32.3
BobLaske
Post by BobLaske » Sat Jun 27, 2020 12:27 am
No, nothing shows up after I run an alarm manually. Maybe I need to upgrade and start from there.
