Installing webcams
bugmenot
Installing webcams
Post by bugmenot »
I have 2 webcams
046d:09a6 Logitech QuickCam Vision Pro
046d:0850 Logitech QuickCam Web
and i try to install these to my Raspberry/Raspbian and lsusb sees these but i can't figure out correct Monitor settings.
Source Type: Local
Device Path: /dev/video0
Capture Method: Video For Linux version 2
Maybe Device Path is wrong? If i go to /dev/ there is video0, video10, video11, video12 and in v4l is by-id and by-path and there are some files with long names.
I got Raspberry Pi Camera Module 2.1 working.
burger
Re: Installing webcams
Post by burger »
Review similar webcam settings at: https://wiki.zoneminder.com/Hardware_Compatibility_List
Perhaps ffmpeg can write from the device file input to an output file e.g. (syntax may be wrong, but something like)
ffmpeg -i /dev/video0 output.mp4
You can watch dmesg when it loads. Assuming you have the module needed for the kernel it should load and may tell you some information. On my device I get:
[ 1111.112065] usb 7-1: new high-speed USB device number 3 using ehci-pci
[ 1111.868095] usb 7-1: device descriptor read/64, error -71
[ 1112.391823] usb 7-1: New USB device found, idVendor=046d, idProduct=0826
[ 1112.391830] usb 7-1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 1112.391835] usb 7-1: Product: HD Webcam C525
[ 1112.391840] usb 7-1: SerialNumber: A8403AA0
[ 1112.578138] media: Linux media interface: v0.10
[ 1112.593307] Linux video capture interface: v2.00
[ 1112.671787] usb 7-1: set resolution quirk: cval->res = 384
[ 1112.672074] usbcore: registered new interface driver snd-usb-audio
[ 1112.672246] uvcvideo: Found UVC 1.00 device HD Webcam C525 (046d:0826)
[ 1112.684650] uvcvideo 7-1:1.2: Entity type for entity Extension 5 was not initialized!
[ 1112.684655] uvcvideo 7-1:1.2: Entity type for entity Processing 2 was not initialized!
[ 1112.684657] uvcvideo 7-1:1.2: Entity type for entity Camera 1 was not initialized!
[ 1112.684660] uvcvideo 7-1:1.2: Entity type for entity Extension 6 was not initialized!
[ 1112.684662] uvcvideo 7-1:1.2: Entity type for entity Extension 7 was not initialized!
[ 1112.684665] uvcvideo 7-1:1.2: Entity type for entity Extension 8 was not initialized!
[ 1112.684800] input: HD Webcam C525 as /devices/pci0000:00/0000:00:1a.7/usb7/7-1/7-1:1.2/input/input15
[ 1112.684926] usbcore: registered new interface driver uvcvideo
[ 1112.684927] USB Video Class driver (1.1.1)
[ 1116.520168] usb 7-1: USB disconnect, device number 3
[ 1116.788128] usb 7-1: new high-speed USB device number 4 using ehci-pci
[ 1117.204293] usb 7-1: New USB device found, idVendor=046d, idProduct=0826
[ 1117.204300] usb 7-1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 1117.204305] usb 7-1: Product: HD Webcam C525
[ 1117.204309] usb 7-1: SerialNumber: A8403AA0
[ 1117.486534] usb 7-1: set resolution quirk: cval->res = 384
[ 1117.487461] uvcvideo: Found UVC 1.00 device HD Webcam C525 (046d:0826)
[ 1117.500296] uvcvideo 7-1:1.2: Entity type for entity Extension 5 was not initialized!
[ 1117.500307] uvcvideo 7-1:1.2: Entity type for entity Processing 2 was not initialized!
[ 1117.500315] uvcvideo 7-1:1.2: Entity type for entity Camera 1 was not initialized!
[ 1117.500322] uvcvideo 7-1:1.2: Entity type for entity Extension 6 was not initialized!
[ 1117.500330] uvcvideo 7-1:1.2: Entity type for entity Extension 7 was not initialized!
[ 1117.500337] uvcvideo 7-1:1.2: Entity type for entity Extension 8 was not initialized!
[ 1117.500742] input: HD Webcam C525 as /devices/pci0000:00/0000:00:1a.7/usb7/7-1/7-1:1.2/input/input16
Here it uses the uvcvideo driver. Notice that the last entry details the path. If I cd to /sys and then to /devices/pci0000:00/0000:00:1a.7/usb7/7-1/7-1:1.2/input/input16, it has a video4linux folder with the name video0. That video0 also happens to be the same in /dev/video0. You will still need to configure the settings for the raw webcam encoding. You can guess, look at existing webcams in the wiki, or try to glean it from ffmpeg. In ffmpeg it mentions yuv442p, which happens to be 'one' of the supported modes of this camera in zm under YUYV.
EDIT: https://www.linuxtv.org/wiki/index.php/V4L_capturing
apt-get install v4l-utils
$ sudo v4l2-ctl  --list-devices
HD Webcam C525 (usb-0000:00:1a.7-1):
        /dev/video0
fastest way to test streams:
