I have installed zoneminder into debian LXC container and it seems works OK. But when I try to run "systemctl start zoneminder" it returns error and I see logs with following info:
-- Subject: Unit failed
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- The unit zoneminder.service has entered the 'failed' state with result 'exit-
Jan 02 21:05:59 CCTV systemd[1]: Failed to start ZoneMinder CCTV recording and s
-- Subject: A start job for unit zoneminder.service has failed
-- A start job for unit zoneminder.service has finished with a failure.
-- The job identifier is 839 and the job result is failed.
Jan 02 21:05:59 CCTV systemd[1]: session-c14.scope: Succeeded.
-- Subject: Unit succeeded
-- The unit session-c14.scope has successfully entered the 'dead' state.
Thanks for your attention,
Regards.
