I got Zoneminder 1.33.15 in Debian Buster.
I installed it from deb-multimedia.
I test it with a old USB webcam. It works, and i got a Picture. But when i open log, i got so many errors.
Is this normel, or have i to search for any problem in my system:
2019-12-27 16:54:06 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x57 0xf5 zm_jpeg.cpp 47
2019-12-27 16:47:59 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x34 0x9c zm_jpeg.cpp 47
2019-12-27 16:21:50 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0xe0 0xd4 zm_jpeg.cpp 47
2019-12-27 16:12:20 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x0d 0xa7 zm_jpeg.cpp 47
2019-12-27 16:03:18 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x8c 0x12 zm_jpeg.cpp 47
2019-12-27 15:48:17 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x92 0x30 zm_jpeg.cpp 47
2019-12-27 15:48:04 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0xa1 0x5b zm_jpeg.cpp 47
2019-12-27 15:42:50 zms_m27 13898 ERR Can't sendto on sd 7: No such file or directory zm_monitorstream.cpp 286
2019-12-27 15:42:50 zms_m27 13898 ERR Terminating, last frame sent time 87.825297 secs more than maximum of 10.000000 zm_monitorstream.cpp 769
2019-12-27 15:42:50 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x0d 0xd9 zm_jpeg.cpp 47
2019-12-27 15:42:44 web_php 12537 ERR Timed out waiting for msg /var/run/zm/zms-743795s.sock /usr/share/zoneminder/www/ajax/stream.php 95
2019-12-27 15:42:44 web_php 12537 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 15:42:42 web_js 13104 ERR getStreamCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=watch
2019-12-27 15:42:09 web_php 13585 ERR Timed out waiting for msg /var/run/zm/zms-743795s.sock /usr/share/zoneminder/www/ajax/stream.php 95
2019-12-27 15:42:09 web_php 13585 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 15:39:31 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x06 0xc4 zm_jpeg.cpp 47
2019-12-27 15:39:27 web_js 13831 ERR getStreamCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=watch
2019-12-27 15:39:21 web_php 12536 ERR Timed out waiting for msg /var/run/zm/zms-184304s.sock /usr/share/zoneminder/www/ajax/stream.php 95
2019-12-27 15:39:21 web_php 12536 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 15:39:21 zms_m27 13832 ERR Can't sendto on sd 7: No such file or directory zm_monitorstream.cpp 286
2019-12-27 15:37:58 web_php 13104 ERR Timed out waiting for msg /var/run/zm/zms-944149s.sock /usr/share/zoneminder/www/ajax/stream.php 95
2019-12-27 15:37:58 web_php 13104 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 15:37:56 web_js 13109 ERR getStreamCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=watch
2019-12-27 15:37:47 web_php 13583 ERR Timed out waiting for msg /var/run/zm/zms-944149s.sock /usr/share/zoneminder/www/ajax/stream.php 95
2019-12-27 15:37:47 web_php 13583 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 15:36:36 web_php 13163 ERR Socket /var/run/zm/zms-878327s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 15:36:34 web_php 13104 ERR Socket /var/run/zm/zms-878327s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 15:36:34 web_js 13104 ERR getStreamCmdResponse stream error: Socket /var/run/zm/zms-878327s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors() ?view=watch
2019-12-27 15:36:11 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0xc3 0xef zm_jpeg.cpp 47
2019-12-27 15:35:52 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x53 0xd3 zm_jpeg.cpp 47
2019-12-27 15:23:59 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0xbb 0x20 zm_jpeg.cpp 47
2019-12-27 15:23:47 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x3a 0x93 zm_jpeg.cpp 47
2019-12-27 15:19:26 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x89 0xd2 zm_jpeg.cpp 47
2019-12-27 15:19:22 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0xed 0x52 zm_jpeg.cpp 47
2019-12-27 15:18:06 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0xcd 0x2d zm_jpeg.cpp 47
2019-12-27 15:18:03 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x35 0x6a zm_jpeg.cpp 47
2019-12-27 15:04:10 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x9a 0x6f zm_jpeg.cpp 47
2019-12-27 15:03:56 zmc_dvideo0 13362 ERR Not a JPEG file: starts with 0x32 0xb4 zm_jpeg.cpp 47
2019-12-27 14:57:12 web_php 12537 ERR Timed out waiting for msg /var/run/zm/zms-558228s.sock /usr/share/zoneminder/www/ajax/stream.php 95
2019-12-27 14:57:12 web_php 12537 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 14:57:10 web_php 12536 ERR Timed out waiting for msg /var/run/zm/zms-558228s.sock /usr/share/zoneminder/www/ajax/stream.php 95
2019-12-27 14:57:10 web_php 12536 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 14:57:10 web_js 12536 ERR getStreamCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=watch
2019-12-27 14:55:47 web_js 13109 ERR getStreamCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=watch
2019-12-27 14:55:47 zms_m27 13559 ERR Can't sendto on sd 7: No such file or directory zm_monitorstream.cpp 286
2019-12-27 14:55:46 web_php 13109 ERR Timed out waiting for msg /var/run/zm/zms-244304s.sock /usr/share/zoneminder/www/ajax/stream.php 95
2019-12-27 14:55:46 web_php 13109 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 14:55:30 web_js 12536 ERR getStreamCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=watch
2019-12-27 14:55:29 web_php 12536 ERR Timed out waiting for msg /var/run/zm/zms-114039s.sock /usr/share/zoneminder/www/ajax/stream.php 95
2019-12-27 14:55:29 web_php 12536 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 14:55:29 zms_m27 13550 ERR Can't sendto on sd 7: No such file or directory zm_monitorstream.cpp 286
2019-12-27 14:54:23 web_js 13109 ERR getStreamCmdResponse stream error: Socket /var/run/zm/zms-780966s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors() ?view=watch
2019-12-27 14:54:22 web_php 13109 ERR Socket /var/run/zm/zms-780966s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 14:37:41 web_php 13104 ERR Socket /var/run/zm/zms-749282s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 14:37:39 web_php 12537 ERR Socket /var/run/zm/zms-749282s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2167
2019-12-27 14:37:39 web_js 12537 ERR getStreamCmdResponse stream error: Socket /var/run/zm/zms-749282s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors() ?view=watch
2019-12-27 14:21:22 zmwatch 13164 ERR Memory map file '/dev/shm/zm.mmap.27' does not exist. zmc might not be running. zmwatch.pl
