zoneminder notwork with mysql8
stonygate
Post by stonygate » Sat Dec 14, 2019 12:31 pm
Hi, I recently moved from ubuntu 8.04 to 8.10
during the installation of the new system, I kept the configurations of the previous one, with the only exception of mysql that from version 5 I moved to 8.
I immediately had problems with all the programs that used mysql, I proceeded with the complete uninstallation of mysql encountering not a few problems.
I managed to install it correctly, it seems to work correctly except for zoneminder.
if I log in it gives me an error: Invalid username or password.
restarting zonemninder from terminal and using journalctl -xe gives me this error:
[zma_m1] [Can't run query: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version of the syntax right
what can I do for correct it?
Re: zoneminder notwork with mysql8
Post by bbunge » Sat Dec 14, 2019 3:35 pm
For now go back to Ubuntu 18.04, which will mean you have to start over. I have not been successful getting any version of Zoneminder to run on Ubuntu 19.10 with MySQL or Mariadb. One of these days I'll get the time to do some work on it after I get all the projects around the new house up to date.
bb
Post by rockedge » Mon Dec 16, 2019 2:01 pm
@bbunge
I did not know about ZM not running in 19.10...but I do have it running in Void Linux which is using the very latest mariaDB. The main issue I think is the mysql query functions have some syntax depreciated for example replace every mysql_* function call with its equivalent mysqli_*
on this Void system I am running Hiawatha, php 7.4 and the 10.1.30-MariaDB Source distribution and ZM 1.33.15 zmNinja 1.3.082
Post by bbunge » Sat Dec 21, 2019 2:56 am
Well we all know Mariadb is different from Mysql. I tried 19.10 with Mariadb 10.4 and did not get Zoneminder to work but not because of database errors.
bkjaya1952
Post by bkjaya1952 » Tue Dec 31, 2019 1:42 pm
I have successfully installed Zoneminder 1.33 with Maridb 10 on Ubuntu 19.10.
Please see the link for installation details.
https://bkjaya.wordpress.com/2019/11/03 ... th-mriadb/
You can also use docker Zoneminder on Ubuntu 19.10 as an alternative
https://hub.docker.com/r/bkjaya1952/docker-zoneminder
According to Isaac Connor , mysql 8 problem with Zoneminder has been solved now.Please refer the following link
https://github.com/ZoneMinder/zoneminder/issues/2685
Post by bbunge » Tue Dec 31, 2019 4:30 pm
Better install package:
https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.33.x
Thanks bkjaya1952 for the fix! There are some things in your procedure that are not needed.
Edit: Working on an install using MySQL8. May have a fix for the Zoneminder package not setting up a user...
bkjaya1952
Post by bkjaya1952 » Fri Jan 03, 2020 7:29 pm
I have managed to install zoneminder with mysql 8 successfully on Ubuntu 19.10
Please see the following my posts to get the installation
https://bkjaya.wordpress.com/2020/01/04 ... ntu-19-10/
https://wiki.zoneminder.com/File:Zonemi ... ysql8_.pdf
Post by bbunge » Fri Jan 03, 2020 7:50 pm
https://wiki.zoneminder.com/File:Zm_with_mysql8.pdf
You do not need to add the timezone in php.ini
Next, we should get this to work with the enhanced mysql security! Until that happens I recommend sticking with Mariadb.
bkjaya1952
Post by bkjaya1952 » Sat Jan 04, 2020 7:08 am
Yes . You can change TIMEZONE later under Options/System/TIMEZONE in latest Zoneminder versions.
The use of Maradb instead of Mysql may not improve the security level of data base. In my case , I have used a password for mysql-server-8
The main problem is the present PHP release make errors with the "caching_sha2_password" introduced in the Mysql 8 by default .
https://www.php.net/manual/en/mysqli.requirements.php
Therefore , we will have to use "mysql_native_password" method in Mysql 8.
There is always risks in any system .No one can build a 100% foolproof system. I am of the opinion that ,there is no harm in finding ways and means to use present Mysql 8 & php with Zoneminder and share the experience with others , without waiting someone to fix the problems.
Post by bbunge » Sun Jan 05, 2020 9:17 pm
Cannot get the procedure to work with MySQL8. Error creating zm database/user:
Procedure fails to secure the MySQL database root password
Have added: default_authentication_plugin = mysql_native_password to /etc/mysql/mysql.conf.d/mysqld.conf
Creating zm db
ERROR 1064 (42000) at line 1: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'identified by "zmpass"' at line 1
DBI connect('database=zm;host=localhost','zmuser',...) failed: Access denied for user 'zmuser'@'localhost' (using password: YES) at /usr/share/perl5/ZoneMinder/Database.pm line 110.
01/05/2020 16:11:08.204181 zmupdate[8454].ERR [ZoneMinder::Database:113] [Error reconnecting to db: errstr:Access denied for user 'zmuser'@'localhost' (using password: YES) error val:]
01/05/2020 16:11:08.204394 zmupdate[8454].ERR [ZoneMinder::Database:113] [Error reconnecting to db: errstr:Access denied for user 'zmuser'@'localhost' (using password: YES) error val:]
01/05/2020 16:11:08.205129 zmupdate[8454].ERR [ZoneMinder::Database:113] [Error reconnecting to db: errstr:Access denied for user 'zmuser'@'localhost' (using password: YES) error val:]
Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/ZoneMinder/Config.pm line 96.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 147.
Compilation failed in require at /usr/bin/zmupdate.pl line 73.
BEGIN failed--compilation aborted at /usr/bin/zmupdate.pl line 73.
01/05/2020 16:11:08.263248 zmupdate[8455].ERR [ZoneMinder::Database:113] [Error reconnecting to db: errstr:Access denied for user 'zmuser'@'localhost' (using password: YES) error val:]
01/05/2020 16:11:08.263462 zmupdate[8455].ERR [ZoneMinder::Database:113] [Error reconnecting to db: errstr:Access denied for user 'zmuser'@'localhost' (using password: YES) error val:]
01/05/2020 16:11:08.264097 zmupdate[8455].ERR [ZoneMinder::Database:113] [Error reconnecting to db: errstr:Access denied for user 'zmuser'@'localhost' (using password: YES) error val:]
Done Updating; starting ZoneMinder.
zoneminder.service is a disabled or a static u
bkjaya1952
Post by bkjaya1952 » Mon Jan 06, 2020 12:20 pm
In order to have clean mysql-server-8.0 install , it is better to completely delete exiting mysql as follows
sudo apt remove --purge mysql-server mysql-client mysql-common
sudo apt autoremove
sudo apt autoclean
sudo rm -rf /etc/mysql
Post by bbunge » Mon Jan 06, 2020 8:46 pm
sudo apt autoremove
sudo apt autoclean
I start with a clean install every time I test. I have images of the Ubuntu and Debian releases with LAMP (either MySQL or Mariadb) which have no root passwords for the database server and no configurations beyond a basic install. So my tests with 19.10/MySQL 8 are fresh and have failed every time. I do not use a desktop version but a minimal server install.
Post by bbunge » Tue Jan 07, 2020 2:33 am
I was able to get Zoneminder to work with MySQL 8. Your procedure is not quite right. I was able to use your basics. I will correct the procedure and post to the WIKI hopefully tomorrow. Has been a bad day for me, computer wise, until I was able to get this to work.
bkjaya1952
Post by bkjaya1952 » Tue Jan 07, 2020 5:52 am
:lol: I am happy , you have at least slightly mentioned that you have used my basics. I have worked very hard to find the solution what you called the "basics". I think that ,the ' basics' is the most important part of the solution. I always appreciate constructive criticism . But, some people are used to copy the technical findings of others , while condemning it totally .
bkjaya1952
Post by bkjaya1952 » Tue Jan 07, 2020 8:59 am
If you are not sure about the installation procedure , please see the following screen shots which show mysql and Zoneminder running
https://www.dropbox.com/s/sjrw5a6w4462f ... 3.png?dl=0
https://www.dropbox.com/s/yl3nk6q6r1noh ... 0.png?dl=0
https://www.dropbox.com/s/5xsrjospvglp5 ... 8.png?dl=0
