NVR Model: LV-N9616D6E
Firmware: V3.4.96 build 171201
Ensure ONVIF is enabled and a user has been added.
- Configuration/Network/Advanced Settings/Integration Protocol
-- Enable ONVIF checkbox
-- Add user
On Zoneminder Console page, Add Cameras using ONVIF
- Click Add button, then Click ONVIF at top right
-- You should see the NVR listed under "Detected Cameras" (it should show model and ip address)
-- Enter username and password for ONVIF user created in previous step
-- Under "Detected Profiles" you should find all cameras attached to NVR
-- Save after camera is chosen, then go back and edit additional settings if needed
