DS-2DE3304W-DE PTZ
joeCarmon
DS-2DE3304W-DE PTZ
Post by joeCarmon » Sun Nov 24, 2019 2:13 am
Has anybody gotten the Hikvision DS-2DE3304W-DE to work for PTZ? I have been struggling with this for quite some time. The camera streams, but I am unable to control it.
joeCarmon
Re: DS-2DE3304W-DE PTZ
Post by joeCarmon » Sun Nov 24, 2019 3:43 am
Minor Update. I have set it for ONVIF, and think I am on the right track, but am getting http::80 (Bad hostname) in the error log for zmcontrol.
joeCarmon
Post by joeCarmon » Tue Dec 03, 2019 7:18 pm
Bumping to see if anybody has any ideas.
security_dude
Post by security_dude » Wed Dec 11, 2019 1:21 pm
I have it working on my machine. Make sure you are using this syntax under the control tab for the control address.
userid:password@server IP:port number
For example admin:passwrod@192.168.1.200:80
Did you create a script for it yet? The control device under the same tab should be your script name. Hope this helps.
Post by rockedge » Thu Dec 12, 2019 4:54 pm
does the Hikvision.pm work for these DS-2DE3304W-DE cameras?
Are the control commands correct in the control script?
security_dude
Post by security_dude » Sun Dec 15, 2019 10:40 pm
PM sent with modified script for you to try out.
Post by rockedge » Mon Dec 16, 2019 1:53 pm
Thanks! I am reviewing some of the different control scripts so this info helps!
kobold81
Post by kobold81 » Sun Dec 29, 2019 11:28 pm
I have the DS-2DE2A404IW-DE3 working with the HikVision script provided by zoneminder.
Control Device: DS-2DE2A404IW-DE3
Control Address: admin:Password@10.10.4.21
Control Type: HikVision
Then click "Edit" next to Control Type.
Move: I clicked everything on
I entered Values at Pan, Tilt, zoom and clicked zoom on on.
I am still trying to figure out if a change in e.g. Pan steps dies anything ;-)
kingsize
Post by kingsize » Tue Jul 21, 2020 4:47 pm
Thank you for posting. Can finally control my two from zm.
jcarmon
Post by jcarmon » Tue Dec 08, 2020 8:20 pm
I am working on getting the same camera up and running, would you care to post your script?
Paranoid
Post by Paranoid » Fri Jan 15, 2021 4:43 pm
Can you goto the following url on your camera and post the output?
http://<your camera>/ISAPI/PTZCtrl/channels/1/capabilities
