Get a camera not mounted
BigChris
Post by BigChris » Sun Oct 06, 2019 7:45 pm
I have successfully integrated four different cameras so far. With my current one, a Hikam S6, I just can't do it.
In VLC I can watch the stream at this address: rtsp://10.10.12.41:554/onvif1
In Zoneminder I tried the following settings:
Source Type: Libvlc
Function: Monitor
Source: rtsp://10.10.12.41:554/onvif1
Method: Tcp, UDP, HTTP Tunnel
Unfortunately, it's not working. What can I do?
CountyLine
Re: Get a camera not mounted
Post by CountyLine » Sun Oct 06, 2019 8:41 pm
Try
Source Type: Ffmpeg
Method: TCP
If that does not work, check the camera manufacturer's website or search the web for something other than onvif1 for that model.
Post by bbunge » Tue Oct 08, 2019 2:05 pm
Check the resolution VLC reports. Some cameras use a resolution that is different than advertised. Also, a high res can can run your server out of space in /dev/shm
flow
Post by flow » Fri Jul 31, 2020 6:17 pm
Hello, i have the same issue.... is there a solution?
on onvif device manager it works
on vlc mediaplayer it works
But with zoneminder not... why it works everywhere without config but not with zoneminder?
Log:
Unable to open input rtsp://10.0.1.51:554/onvif1 due to: Invalid data found when processing input
Thanks in Advance!
flow
Post by flow » Fri Jul 31, 2020 6:52 pm
Haha okey guys i got it working! xD
do not use TCP
HiKam of the first generation:
Source Type: ffmpeg
Source Path: rtsp://10.0.1.54:554/onvif1
Remote Method: UDP
