Error Zoneminder 1.33.x and FFMPEG 3.4.6 Ubuntu Bioniq
reksoz
Post by reksoz »
Hi , I update version Ubuntu Bionic with Armbian Linux 4.19.62-sunxi and zoneminder 1.33.14 and now zoneminder not work.
Now in the log file this error appears in all cameras.
ERR Unable to convert format xx to format 28 at frame 0 codec xx
Any Idea?
	Component 	Server 	PID 	Level 	Message 	File 	Line
2019-08-28 10:09:32	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:32	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:32	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:32	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:32	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:32	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:30	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:30	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:29	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:29	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:28	zmc_m2		20837	ERR	Unable to open input rtsp://xxxx:xxxx@192.168.1.252:10554/tcp/av0_0 due to: No route to host	zm_ffmpeg_camera.cpp	373
2019-08-28 10:09:27	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:27	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:27	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:27	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:25	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:25	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:25	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:25	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:23	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:23	zma_m2		20832	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:09:23	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:23	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:09:22	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:22	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:22	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:22	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:20	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:20	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:18	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:18	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:18	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:18	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:17	zma_m2		20822	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:09:17	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:09:16	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:16	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:16	zma_m2		20817	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:09:16	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:09:16	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:16	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:15	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:15	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:13	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:13	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:11	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:11	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:11	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:11	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:11	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:11	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:09	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:09	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:08	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:08	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:07	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:07	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:06	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:06	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:05	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:05	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:05	zmc_m2		20719	ERR	Unable to open input rtsp://xxxx:xxxx@192.168.1.252:10554/tcp/av0_0 due to: No route to host	zm_ffmpeg_camera.cpp	373
2019-08-28 10:09:05	zmc_m2		20719	ERR	Failed to prime capture of initial monitor	zmc.cpp	257
2019-08-28 10:09:04	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:04	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:02	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:02	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:01	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:01	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:09:01	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:09:01	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:59	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:59	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:58	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:58	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:57	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:57	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:56	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:56	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:55	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:55	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:54	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:54	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:52	zmc_m2		20719	ERR	Unable to open input rtsp://xxxx:xxxx@192.168.1.252:10554/tcp/av0_0 due to: No route to host	zm_ffmpeg_camera.cpp	373
2019-08-28 10:08:52	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:52	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:51	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:51	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:51	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:51	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:50	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:50	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:48	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:48	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:47	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:47	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:46	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:46	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:45	zma_m2		20713	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:08:45	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:08:45	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:45	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:44	zma_m2		20708	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:08:44	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:08:44	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:44	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:43	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:43	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:41	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:41	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:41	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:41	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:41	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:41	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:38	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:38	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:37	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:37	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:36	zmc_m4		20675	ERR	Unable to convert format 12 to format 28 at frame 0 codec 12	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:36	zmc_m4		20675	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:36	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:36	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:35	zmc_m2		20660	ERR	Unable to open input rtsp://xxxx:xxxx@192.168.1.252:10554/tcp/av0_0 due to: No route to host	zm_ffmpeg_camera.cpp	373
2019-08-28 10:08:34	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:34	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:34	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:34	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:32	zma_m2		20657	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:08:32	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:08:31	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:31	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:30	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:30	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:29	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:29	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:29	web_php		20038	ERR	Setting to disabled	/usr/share/zoneminder/www/includes/functions.php	530
2019-08-28 10:08:27	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:27	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:27	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:27	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:24	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:24	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:23	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:23	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:22	zmc_m2		20631	ERR	Unable to open input rtsp://xxxx:xxxx@192.168.1.252:10554/tcp/av0_0 due to: No route to host	zm_ffmpeg_camera.cpp	373
2019-08-28 10:08:22	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:22	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:20	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:20	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:20	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:20	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:17	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:17	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:17	zmwatch		19980	ERR	Memory map file '/dev/shm/zm.mmap.2' should have been 1160 but was instead 0	zmwatch.pl
2019-08-28 10:08:16	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:16	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:15	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:15	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:14	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:08:14	zma_m2		20620	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:08:13	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:13	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:13	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:13	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:10	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:10	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:09	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:09	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:09	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:08:09	zma_m2		20612	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:08:08	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:08	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:07	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:08:07	zma_m2		20607	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:08:06	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:06	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:06	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:06	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:06	zmdc		19886	ERR	'zma -m 2' exited abnormally, exit status 255	zmdc.pl
2019-08-28 10:08:05	zma_m2		20595	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	567
2019-08-28 10:08:05	zmwatch		19980	ERR	Memory map file '/dev/shm/zm.mmap.2' does not exist. zmc might not be running.	zmwatch.pl
2019-08-28 10:08:03	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:03	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:03	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:03	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:08:01	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:08:01	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:07:59	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:07:59	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:07:59	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:07:59	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:07:56	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:07:56	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:07:56	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:07:56	zmc_m1		19917	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:07:54	zmc_m3		20549	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp	998
2019-08-28 10:07:54	zmc_m3		20549	ERR	Unable to convert format 0 to format 28 at frame 0 codec 0	zm_ffmpeg_camera.cpp	1109
2019-08-28 10:07:54	zmc_m2		20570	ERR	Unable to open input rtsp://xxxx:xxxx@192.168.1.252:10554/tcp/av0_0 due to: Interrupted system call	zm_ffmpeg_camera.cpp	373
2019-08-28 10:07:52	zmwatch		19980	ERR	Memory map file '/dev/shm/zm.mmap.2' should have been 1160 but was instead 0	zmwatch.pl
2019-08-28 10:07:52	zmc_m1		19917	ERR	Failed to transfer from frame to image	zm_ffmpeg_camera.cpp
My ffmpeg version
ffmpeg version 3.4.6-0ubuntu0.18.04.1 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 7 (Ubuntu/Linaro 7.3.0-16ubuntu3)
configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
libavutil      55. 78.100 / 55. 78.100
libavcodec     57.107.100 / 57.107.100
libavformat    57. 83.100 / 57. 83.100
libavdevice    57. 10.100 / 57. 10.100
libavfilter     6.107.100 /  6.107.100
libavresample   3.  7.  0 /  3.  7.  0
libswscale      4.  8.100 /  4.  8.100
libswresample   2.  9.100 /  2.  9.100
libpostproc    54.  7.100 / 54.  7.100
Re: Error Zoneminder 1.33.x and FFMPEG 3.4.6 Ubuntu Bioniq
I have improved that error message to actually tell us the name of the pix formats that it is having trouble with.
I havn't seen this error before.
We will need you to update to latest, and turn on debugging to level 3.
I also might suggest settings your logging settings to LOG_LEVEL_DATABASE => Info or higher so that you don't flood your db with the debug logs.
Set LOG_LEVEL_FILE => Debug
clear LOG_DEBUG_FILE
Now the debug logs will be in /var/log/zm/zmc_m2.log etc.
reksoz
Post by reksoz »
I log in debug mode this files , zm1 and zm4. any idea?
zm_debug_07311.log
(291.39 KiB) Downloaded 110 times
zm_debug.log
(677.06 KiB) Downloaded 112 times
I don't think this is a ZM problem. The only thing I can think of is that it doesn't like the resolution. It might be interesting to try a more standard res like 640x480.
reksoz
Post by reksoz »
Hi
when i upgrade to 1.32.3 works fine. i try down resolution.
reksoz
Post by reksoz »
yes!!! i change the resolutions and works fine. but its strange , no? I had always been to that resolution and it had worked, I don't understand why
thank you very much. :)
ZM 1.33.14 from Master PPA tested on Pi 3B+ with Ubuntu Preinstalled Server (with cloud removed).
Ubuntu versions tested: 18.04-3 and 19.04, armhf and arm64.
My test cameras are old Linksys web cam and Foscam FI8918W (neither have rtsp ability).
New version of ZM works very well on Source Type: Remote.
Source type Ffmpeg can't connect and shows the following in Logs:
F.Y.I. both of these cameras work well on Ubuntu 18.04 amd64 on ZM 1.33.14 with Source Type Remote and Ffmpeg.
Also am pleased to report that video writing does work on the Pi with this version of ZM.
These logs don't show a failure to connect, they show an unassigned destination image format. Normally we choose this in the monitor... 24bit, 32bit, 8bit whatever. Very wierd.
iconnor wrote: Mon Sep 02, 2019 7:29 pm These logs don't show a failure to connect, they show an unassigned destination image format. Normally we choose this in the monitor... 24bit, 32bit, 8bit whatever. Very wierd.
I just used 32bit in all tests. Should I try 8 and 24bit?
bbunge wrote: Mon Sep 02, 2019 8:07 pm
Currently running arm64 Disco and ZM 1.33.14.
Switched to 8 bit grey scale on both cameras. Both worked on Ffmpeg. Went to 24 bit colour and both worked. Went to 32 bit colour and got the same error as before. Video writing still works!
All in all am very pleased this version works as well as it does on Pi. On my "real" test PC running Bionic with Linux 5.0 kernel no issues other than I haven't been able to get the shutdown/restart from ZM to work...
spanner3003
Post by spanner3003 »
Thanks I was have this problem too switching to 24bit help.
I tried everything I recompiled zoneminder to 1.33.14 from master, I recompiled x264 and FFmpeg with different config tags and I had the ffmpeg debugging turned on in zoneminder. I didn't understand a lot of what I saw.
I am running on an odroid xu4 with armbain installed which is Debian 9.
kernel: Linux odroidxu4 5.3.0-rc6-odroidxu4 #5.94.190830 SMP PREEMPT Fri Aug 30 08:14:44 CEST 2019 armv7l GNU/Linux
Linux: Raspbian with Armbian Linux 5.3.0-rc6-odroidxu4.
I was able to run a ffmepg instance in command line writing to a MP4 file and that works fine I was able to read the file with VLC player. My cameras all put out H264 and worked for a long time on zoneminder before, they worked on version 1.32and 1.30 but this latest version seems to have a problem with 32-bit colour.
zmc_m1.log
(210.64 KiB) Downloaded 114 times
