status display numbers?
zd59
Post by zd59 »
Can somebody please explain status figures for load and DB - attached picture
1. what the lightning sign mean
2. Load number? - CPU is i5-7200U, dual core, 4 threads - and what number would be for 100% CPU load (all cores & threads)?
3. DB:X/Y - what numbers X and Y reflect?
kitkat
Re: status display numbers?
Post by kitkat »
zd59 wrote: Mon May 13, 2019 7:14 am 2. Load number? - CPU is i5-7200U, dual core, 4 threads - and what number would be for 100% CPU load (all cores & threads)?
100% load = 1.00 per CPU thread, so for yours that would be 4.00.
zd59
Post by zd59 »
Yes, had in mind too (as htop show), until i've got figures well over 4 (5+).
I'm sure, as that was observed on different systems not only on one.
Could it be overclocking or kernel dealing with CPU states and speed?
kitkat
Post by kitkat »
zd59 wrote: Thu May 16, 2019 1:18 pm Yes, had in mind too (as htop show), until i've got figures well over 4 (5+).
I think that load is actually calculated as something like, "the number of processes requesting CPU time, or instructions in the queue, divided by the number of CPU threads," so load values greater than the amount of threads indicate that processes are having to wait for CPU time rather than being executed immediately - i.e. the system has too much to do (is overloaded) and may be slow to respond.
zd59
Post by zd59 »
Thank you kitkat!
So I'll observe systems with that in mind and act accordingly.
Regards..
