Motion detection is not working
Posted: Thu May 14, 2020 5:44 pm
Hi all.
I have Zoneminder 1.32 on a Raspberry Pi 4 4GB. At the moment just one local camera is attached by an Easycap USB device. It is added in Zoneminder and monitor is working, I can see the video no problem. I have set the frame rate to 10fps as this is adequate for my needs.
I have tried to set up a motion detection zone and nothing will work. Even when there is extreme movement, like the whole camera suddenly being moved, nothing will trigger a recording event. If I click "force alarm" it will record no problem. I also cannot play back any events.
Here's some of my log:
Thanks2020-05-14 17:42:55.129786 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:62700 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:42:47.591958 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 62600 - Analysing at 10.00 fps]
2020-05-14 17:42:45.054671 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:62600 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:42:37.537224 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 62500 - Analysing at 10.00 fps]
2020-05-14 17:42:35.002048 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:62500 - Capturing at 8.33 fps, capturing bandwidth 5120000bytes/sec]
2020-05-14 17:42:27.479116 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 62400 - Analysing at 9.09 fps]
2020-05-14 17:42:23.687674 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:62400 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:42:16.149057 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 62300 - Analysing at 10.00 fps]
2020-05-14 17:42:13.618365 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:62300 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:42:06.078813 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 62200 - Analysing at 10.00 fps]
2020-05-14 17:42:03.554897 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:62200 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:41:56.036837 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 62100 - Analysing at 9.09 fps]
2020-05-14 17:41:53.496078 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:62100 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:41:45.963723 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 62000 - Analysing at 8.33 fps]
2020-05-14 17:41:43.421312 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:62000 - Capturing at 7.69 fps, capturing bandwidth 4726153bytes/sec]
2020-05-14 17:41:33.494153 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61900 - Analysing at 10.00 fps]
2020-05-14 17:41:30.977494 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61900 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:41:23.465202 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61800 - Analysing at 10.00 fps]
2020-05-14 17:41:20.932138 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61800 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:41:14.018852 zms_e78[7423].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2020-05-14 17:41:13.412697 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61700 - Analysing at 10.00 fps]
2020-05-14 17:41:10.884853 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61700 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:41:03.352134 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61600 - Analysing at 10.00 fps]
2020-05-14 17:41:00.833393 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61600 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:40:53.291245 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61500 - Analysing at 10.00 fps]
2020-05-14 17:40:50.784033 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61500 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:40:43.243981 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61400 - Analysing at 10.00 fps]
2020-05-14 17:40:40.733089 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61400 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:40:33.214374 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61300 - Analysing at 10.00 fps]
2020-05-14 17:40:30.698556 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61300 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:40:23.166414 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61200 - Analysing at 10.00 fps]
2020-05-14 17:40:20.641194 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61200 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:40:13.112133 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61100 - Analysing at 10.00 fps]
2020-05-14 17:40:10.590108 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61100 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:40:03.077042 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 61000 - Analysing at 8.33 fps]
2020-05-14 17:40:01.548102 zmu[7712].INF-zm_user.cpp/129 [Authenticated user 'pml']
2020-05-14 17:40:00.532253 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:61000 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:39:51.777277 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60900 - Analysing at 10.00 fps]
2020-05-14 17:39:49.234786 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60900 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:39:41.628856 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60800 - Analysing at 10.00 fps]
2020-05-14 17:39:39.197955 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60800 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:39:31.554395 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60700 - Analysing at 10.00 fps]
2020-05-14 17:39:29.143272 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60700 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:39:21.513559 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60600 - Analysing at 10.00 fps]
2020-05-14 17:39:19.081051 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60600 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:39:11.342606 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60500 - Analysing at 10.00 fps]
2020-05-14 17:39:09.009334 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60500 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:39:01.287356 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60400 - Analysing at 10.00 fps]
2020-05-14 17:38:58.963809 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60400 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:38:51.244766 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60300 - Analysing at 10.00 fps]
2020-05-14 17:38:48.909318 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60300 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:38:41.178887 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60200 - Analysing at 10.00 fps]
2020-05-14 17:38:38.834300 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60200 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:38:31.086222 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60100 - Analysing at 10.00 fps]
2020-05-14 17:38:28.764065 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60100 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:38:21.037186 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 60000 - Analysing at 10.00 fps]
2020-05-14 17:38:18.714246 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:60000 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:38:11.001345 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59900 - Analysing at 9.09 fps]
2020-05-14 17:38:08.677704 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59900 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:38:00.951103 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59800 - Analysing at 10.00 fps]
2020-05-14 17:37:58.624984 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59800 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:37:50.897495 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59700 - Analysing at 10.00 fps]
2020-05-14 17:37:48.559616 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59700 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:37:40.821389 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59600 - Analysing at 10.00 fps]
2020-05-14 17:37:38.505049 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59600 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:37:30.799326 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59500 - Analysing at 10.00 fps]
2020-05-14 17:37:28.469508 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59500 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:37:20.743903 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59400 - Analysing at 10.00 fps]
2020-05-14 17:37:18.409556 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59400 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:37:17.973157 web_js[690].ERR-?view=log [Export request failed: 500 / Internal Server Error - exportFail()]
2020-05-14 17:37:10.684024 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59300 - Analysing at 10.00 fps]
2020-05-14 17:37:08.334432 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59300 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:37:00.609831 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59200 - Analysing at 10.00 fps]
2020-05-14 17:36:58.263424 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59200 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:36:50.524639 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59100 - Analysing at 10.00 fps]
2020-05-14 17:36:48.191905 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59100 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:36:47.941920 zmdc[769].ERR-zmdc.pl ['zmfilter.pl --filter_id=2 --daemon' exited abnormally, exit status 9]
2020-05-14 17:36:47.871540 zmdc[769].ERR-zmdc.pl ['zmfilter.pl --filter_id=1 --daemon' exited abnormally, exit status 9]
2020-05-14 17:36:47.233310 zmdc[7428].INF-zmdc.pl ['zmfilter.pl --filter_id=2 --daemon' started at 20/05/14 17:36:47]
2020-05-14 17:36:47.220290 zmdc[769].INF-zmdc.pl ['zmfilter.pl --filter_id=2 --daemon' starting at 20/05/14 17:36:47, pid = 7428]
2020-05-14 17:36:47.178030 zmdc[769].INF-zmdc.pl [Starting pending process, zmfilter.pl --filter_id=2 --daemon]
2020-05-14 17:36:47.161510 zmdc[7427].INF-zmdc.pl ['zmfilter.pl --filter_id=1 --daemon' started at 20/05/14 17:36:47]
2020-05-14 17:36:47.159210 zmdc[769].INF-zmdc.pl ['zmfilter.pl --filter_id=1 --daemon' starting at 20/05/14 17:36:47, pid = 7427]
2020-05-14 17:36:47.138130 zmdc[769].INF-zmdc.pl [Starting pending process, zmfilter.pl --filter_id=1 --daemon]
2020-05-14 17:36:46.122530 zmdc[769].ERR-zmdc.pl ['zmaudit.pl -c' exited abnormally, exit status 255]
2020-05-14 17:36:46.096210 zmaudit[7425].FAT-zmaudit.pl [zmaudit.pl appears to already be running at pid 850. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option.]
2020-05-14 17:36:45.653540 zmdc[7425].INF-zmdc.pl ['zmaudit.pl -c' started at 20/05/14 17:36:45]
2020-05-14 17:36:45.643200 zmdc[769].INF-zmdc.pl ['zmaudit.pl -c' starting at 20/05/14 17:36:45, pid = 7425]
2020-05-14 17:36:45.616430 zmdc[769].INF-zmdc.pl [Starting pending process, zmaudit.pl -c]
2020-05-14 17:36:40.459219 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 59000 - Analysing at 10.00 fps]
2020-05-14 17:36:38.143561 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:59000 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:36:30.396293 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58900 - Analysing at 10.00 fps]
2020-05-14 17:36:28.073812 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58900 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:36:20.331039 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58800 - Analysing at 10.00 fps]
2020-05-14 17:36:18.019373 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58800 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:36:15.761734 web_js[691].ERR-?view=event [getCmdResponse stream error: No data to read from socket - checkStreamForErrors()]
2020-05-14 17:36:15.638206 web_php[691].ERR-/usr/share/zoneminder/www/includes/functions.php/2051 [No data to read from socket]
2020-05-14 17:36:15.623402 web_php[691].ERR-/usr/share/zoneminder/www/ajax/stream.php/90 [Timed out waiting for msg /var/run/zm/zms-592262s.sock]
2020-05-14 17:36:13.841397 zms_e78[7423].INF-zm_user.cpp/129 [Authenticated user 'admin']
2020-05-14 17:36:10.263631 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58700 - Analysing at 10.00 fps]
2020-05-14 17:36:07.953541 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58700 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:36:00.210514 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58600 - Analysing at 10.00 fps]
2020-05-14 17:35:57.895733 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58600 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:35:50.196021 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58500 - Analysing at 10.00 fps]
2020-05-14 17:35:47.858168 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58500 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:35:40.162150 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58400 - Analysing at 10.00 fps]
2020-05-14 17:35:37.839282 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58400 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:35:30.131519 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58300 - Analysing at 7.69 fps]
2020-05-14 17:35:27.818537 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58300 - Capturing at 8.33 fps, capturing bandwidth 5120000bytes/sec]
2020-05-14 17:35:17.611474 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58200 - Analysing at 10.00 fps]
2020-05-14 17:35:15.282469 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58200 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:35:07.564031 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58100 - Analysing at 10.00 fps]
2020-05-14 17:35:05.249747 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58100 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:34:57.538664 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 58000 - Analysing at 9.09 fps]
2020-05-14 17:34:55.209762 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:58000 - Capturing at 8.33 fps, capturing bandwidth 5120000bytes/sec]
2020-05-14 17:34:46.237506 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57900 - Analysing at 10.00 fps]
2020-05-14 17:34:43.909418 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57900 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:34:36.199319 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57800 - Analysing at 10.00 fps]
2020-05-14 17:34:33.893101 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57800 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:34:26.186025 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57700 - Analysing at 10.00 fps]
2020-05-14 17:34:23.873902 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57700 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:34:16.176112 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57600 - Analysing at 10.00 fps]
2020-05-14 17:34:13.849457 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57600 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:34:06.130028 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57500 - Analysing at 8.33 fps]
2020-05-14 17:34:03.808576 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57500 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:33:54.864465 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57400 - Analysing at 10.00 fps]
2020-05-14 17:33:52.525844 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57400 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:33:44.795711 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57300 - Analysing at 10.00 fps]
2020-05-14 17:33:42.467826 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57300 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:33:34.757244 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57200 - Analysing at 9.09 fps]
2020-05-14 17:33:32.426988 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57200 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:33:23.446586 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57100 - Analysing at 10.00 fps]
2020-05-14 17:33:21.127848 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57100 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:33:13.419263 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 57000 - Analysing at 10.00 fps]
2020-05-14 17:33:11.088011 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:57000 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:33:03.373923 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56900 - Analysing at 10.00 fps]
2020-05-14 17:33:01.054103 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56900 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:32:53.338076 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56800 - Analysing at 10.00 fps]
2020-05-14 17:32:51.030925 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56800 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:32:43.313206 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56700 - Analysing at 10.00 fps]
2020-05-14 17:32:41.005278 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56700 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:32:33.257439 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56600 - Analysing at 10.00 fps]
2020-05-14 17:32:30.939056 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56600 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:32:23.232253 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56500 - Analysing at 10.00 fps]
2020-05-14 17:32:20.910560 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56500 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:32:13.205425 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56400 - Analysing at 10.00 fps]
2020-05-14 17:32:10.863420 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56400 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:32:03.127357 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56300 - Analysing at 10.00 fps]
2020-05-14 17:32:00.798392 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56300 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:31:53.105255 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56200 - Analysing at 10.00 fps]
2020-05-14 17:31:50.777680 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56200 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:31:43.081098 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56100 - Analysing at 8.33 fps]
2020-05-14 17:31:40.753192 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56100 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:31:31.858466 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 56000 - Analysing at 10.00 fps]
2020-05-14 17:31:29.537265 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:56000 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:31:21.846217 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55900 - Analysing at 10.00 fps]
2020-05-14 17:31:19.509452 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55900 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:31:11.768645 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55800 - Analysing at 10.00 fps]
2020-05-14 17:31:09.447640 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55800 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:31:01.709470 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55700 - Analysing at 7.69 fps]
2020-05-14 17:30:59.379490 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55700 - Capturing at 7.69 fps, capturing bandwidth 4726153bytes/sec]
2020-05-14 17:30:48.397927 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55600 - Analysing at 10.00 fps]
2020-05-14 17:30:46.067529 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55600 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:30:38.361909 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55500 - Analysing at 10.00 fps]
2020-05-14 17:30:36.025265 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55500 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:30:28.282467 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55400 - Analysing at 10.00 fps]
2020-05-14 17:30:25.961318 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55400 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:30:18.237564 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55300 - Analysing at 8.33 fps]
2020-05-14 17:30:15.905407 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55300 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:30:06.979947 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55200 - Analysing at 10.00 fps]
2020-05-14 17:30:04.641371 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55200 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:30:02.318494 zmu[7025].INF-zm_user.cpp/129 [Authenticated user 'pml']
2020-05-14 17:29:56.936514 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55100 - Analysing at 10.00 fps]
2020-05-14 17:29:54.587679 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55100 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:29:46.892688 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 55000 - Analysing at 9.09 fps]
2020-05-14 17:29:44.561133 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:55000 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:29:35.675158 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 54900 - Analysing at 9.09 fps]
2020-05-14 17:29:33.354595 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:54900 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:29:24.387600 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 54800 - Analysing at 10.00 fps]
2020-05-14 17:29:22.066800 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:54800 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:29:14.347478 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 54700 - Analysing at 10.00 fps]
2020-05-14 17:29:12.031502 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:54700 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:29:04.296098 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 54600 - Analysing at 8.33 fps]
2020-05-14 17:29:01.970364 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:54600 - Capturing at 9.09 fps, capturing bandwidth 5585454bytes/sec]
2020-05-14 17:28:52.988717 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 54500 - Analysing at 10.00 fps]
2020-05-14 17:28:50.660260 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:54500 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:28:42.966083 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 54400 - Analysing at 10.00 fps]
2020-05-14 17:28:40.633419 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:54400 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:28:38.940190 zms_m20[6875].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2020-05-14 17:28:36.560130 zms_m20[6868].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2020-05-14 17:28:34.235074 zms_m20[6771].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2020-05-14 17:28:33.016581 web_php[692].INF-/usr/share/zoneminder/www/includes/auth.php/69 [User "pml" logged out]
2020-05-14 17:28:32.931662 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 54300 - Analysing at 10.00 fps]
2020-05-14 17:28:30.801049 web_js[1866].ERR-?view=watch [getEventCmdResponse stream error: Unrecognised action or insufficient permissions - checkStreamForErrors()]
2020-05-14 17:28:30.692333 web_php[1866].ERR-/usr/share/zoneminder/www/includes/functions.php/2051 [Unrecognised action or insufficient permissions]
2020-05-14 17:28:30.593764 zmc_dvideo0[832].INF-zm_monitor.cpp/2477 [Penlee: images:54300 - Capturing at 10.00 fps, capturing bandwidth 6144000bytes/sec]
2020-05-14 17:28:25.687835 web_js[1866].ERR-?view=watch [getEventCmdResponse stream error: Unrecognised action or insufficient permissions - checkStreamForErrors()]
2020-05-14 17:28:25.552837 web_php[1866].ERR-/usr/share/zoneminder/www/includes/functions.php/2051 [Unrecognised action or insufficient permissions]
2020-05-14 17:28:22.861789 zma_m20[847].INF-zm_monitor.cpp/1247 [Penlee: 54200 - Analysing at 10.00 fps]
