ZM seems to only save 20 records at a time?
krizzle
Post by krizzle »
I just finished a new installation of Zoneminder on my server (1.32.3). My previous installation on my old machine kept every record recorded using MODEC but this new installation only keep 20 at a time. Is there a reason for this or a setting I can change to keep/view all records?
Thanks.
Re: ZM seems to only save 20 records at a time?
First off 1.32 is no longer supported. Recommend immediate upgrade to 1.34.
Second, something is deleting your events, probably a misconfigured filter.
krizzle
Post by krizzle »
I have updated my ZM instance to 1.34.9 and I see all of my records now thanks!
Just a side note, I noticed when heading to the install page - https://zoneminder.readthedocs.io/en/1. ... buntu.html
the latest release still seems to show 1.32. Not sure if this is a type or intentional.
Thanks.
