zoneminder 1.32.3 dahua ipc-t1a20p
maxnux
Post by maxnux » Fri Jan 10, 2020 4:08 pm
hi i recent install zoneminder 1.32.3 in ubuntu 14.04 whit sudo add-apt-repository ppa:iconnor/zoneminder-1.32 ppa
i can view in vlc onvif conmpatible camera with rtsp://user:pass@192.168.0.xxx:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
But not work in zoneminder , can give some tips ?
snake
Re: zoneminder 1.32.3 dahua ipc-t1a20p
Post by snake » Fri Jan 10, 2020 6:03 pm
See https://wiki.zoneminder.com/Finding_Camera_Stream_Paths
For ZM, resolution must be right, most other fields can be left blank. Don't put in Max FPS for IP cameras. If you are using a (resource constrained) RPI, lower the FPS/Resolution of the camera.
Users browsing this forum: Google [Bot] and 10 guests
