FreeNAS Plugin 1.32.3 API Cake Issue
Posted: Thu Aug 08, 2019 5:37 pm
Hello, I am having an issue with my APIs not working correctly in the ZM FreeNAS plugin on 11.2 U5. Zoneminder has been running well in the web interface, but I cannot get the APIs working correctly. I've been trying all sorts of things to get ZMNinja working for live views, but it looks like I have an issue with CAKE. Using the instructions from ZMNinja and the app developer, I navigated to "http://server/zm/api/monitors.json", but get an error:
The folks from ZMNinjatold me that this is an API issue, but I have no idea where to start to troubleshoot this. This does appear to be the issue causing the APIs to break. I could really use some assistance or direction with helping to troubleshoot my APIs and CAKE.
Respectfully,
<pre class="cake-error"><a href="javascript:void(0);" onclick="document.getElementById('cakeErr5d4c5a5b56414-trace').style.display = (document.getElementById('cakeErr5d4c5a5b56414-trace').style.display == 'none' ? '' : 'none');"><b>Warning</b> (2)</a>: Use of undefined constant utf8 - assumed 'utf8' (this will throw an Error in a future version of PHP) [<b>CORE/Cake/Model/ConnectionManager.php</b>, line <b>69</b>]<div id="cakeErr5d4c5a5b56414-trace" class="cake-stack-trace" style="display: none;"><a href="javascript:void(0);" onclick="document.getElementById('cakeErr5d4c5a5b56414-code').style.display = (document.getElementById('cakeErr5d4c5a5b56414-code').style.display == 'none' ? '' : 'none')">Code</a> <a href="javascript:void(0);" onclick="document.getElementById('cakeErr5d4c5a5b56414-context').style.display = (document.getElementById('cakeErr5d4c5a5b56414-context').style.display == 'none' ? '' : 'none')">Context</a><pre id="cakeErr5d4c5a5b56414-code" class="cake-code-dump" style="display: none;"><code><span style="color: #000000"><span style="color: #0000BB"> </span><span style="color: #007700">include_once </span><span style="color: #0000BB">CONFIG </span><span style="color: #007700">. </span><span style="color: #DD0000">'database.php'</span><span style="color: #007700">;</span></span></code>
<code><span style="color: #000000"><span style="color: #0000BB"> </span><span style="color: #007700">if (</span><span style="color: #0000BB">class_exists</span><span style="color: #007700">(</span><span style="color: #DD0000">'DATABASE_CONFIG'</span><span style="color: #007700">)) {</span></span></code>
<span class="code-highlight"><code><span style="color: #000000"><span style="color: #0000BB"> </span><span style="color: #007700">static::</span><span style="color: #0000BB">$config </span><span style="color: #007700">= new </span><span style="color: #0000BB">DATABASE_CONFIG</span><span style="color: #007700">();</span></span></code></span></pre><pre class="stack-trace">ConnectionManager::_init() - CORE/Cake/Model/ConnectionManager.php, line 69
ConnectionManager::getDataSource() - CORE/Cake/Model/ConnectionManager.php, line 83
Model::setDataSource() - CORE/Cake/Model/Model.php, line 3646
Model::setSource() - CORE/Cake/Model/Model.php, line 1162
Model::getDataSource() - CORE/Cake/Model/Model.php, line 3673
Model::schema() - CORE/Cake/Model/Model.php, line 1394
EnumBehavior::setup() - APP/Plugin/CakePHP-Enum-Behavior/Model/Behavior/EnumBehavior.php, line 34
BehaviorCollection::load() - CORE/Cake/Model/BehaviorCollection.php, line 145
BehaviorCollection::init() - CORE/Cake/Model/BehaviorCollection.php, line 66
Model::__construct() - CORE/Cake/Model/Model.php, line 781
ReflectionClass::newInstance() - [internal], line ??
ClassRegistry::init() - CORE/Cake/Utility/ClassRegistry.php, line 169
Controller::loadModel() - CORE/Cake/Controller/Controller.php, line 741
Controller::__isset() - CORE/Cake/Controller/Controller.php, line 368
Controller::__get() - CORE/Cake/Controller/Controller.php, line 406
CrudComponent::_setModelProperties() - APP/Plugin/Crud/Controller/Component/CrudComponent.php, line 812
CrudComponent::getSubject() - APP/Plugin/Crud/Controller/Component/CrudComponent.php, line 614
CrudComponent::_loadListener() - APP/Plugin/Crud/Controller/Component/CrudComponent.php, line 751</pre></div></pre>{
"monitors": [
............monitor information.................
Respectfully,
