after upgrading to 1.32.3, my cameras are no longer showing FPS. How can this be?
Now it only shows: "State: - fps", the number itself is actually missing.
Thanks.
[SOLVED] Cameras no longer showing FPS
Re: Cameras no longer showing FPS
Can think of lots of reasons. Hard to tell without any information.
How many cameras? There is a limit of 4-6 for most browsers.
Your best best might be right click, inspect Element, click on console tab and see what it says there.
Hi, theres is only 2 cameras, and I have the same issue, if I only look at the single camera.
From your input, I can see a lot of these errors.
So since, the site is served using SSL, and it load contents from an non-ssl site, I get this error.
Actually it seems like the same, og same kinda issue as: https://github.com/ZoneMinder/zoneminder/issues/2316, if looking at the last post.
-- edit --
Here as well: https://github.com/ZoneMinder/zoneminder/issues/2339
-- edit --
- zm_fps_01.png (55.69 KiB) Viewed 3930 times
Any suggestions ?
It's worth noticing, im running an reverse proxy infront of it, where the SSL certificated, and then forwards as normal plain tcp traffic.
This was working fine, with the older 1.30 versions.
Upgrade to 1.33.14 and see what happens.
That is currently not really option for me at this time, I was wondering, if there was some sort of hack that I could create directly to the code.
Seems, that the mootools-core.js sends without https, but only as http.
Part of googles inspector says.
p?view=request&request=stream&connkey=810108&command=99'. This request has been blocked; the content must be served over HTTPS.
send @ mootools-core.js:6432
mootools-core.js:6432 Mixed Content: The page at
Upgraded to 133.16, and its fixed as expected.
TY!
TY!
