virtualhost configuration and API access
flixter
Post by flixter » Tue Jul 23, 2019 12:47 pm
Hi! I have installed ZM 1.32.3 on debian stable, via apt. I have set up a virtualhost for my apache that looks like
<VirtualHost 192.168.0.2:443>
ServerAdmin admin@mydomain.org
ServerName zm.mydomain.org
DocumentRoot /usr/share/zoneminder/www
CustomLog ${APACHE_LOG_DIR}/zm.log vhost_ssl
ScriptAlias /cgi-bin "/usr/lib/zoneminder/cgi-bin"
AllowOverride All
Require all granted
</Directory>
php_flag register_globals off
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
AllowOverride All
# Require all granted
</Directory>
</VirtualHost>
The web interface can be accessed properly, configured and so... however, when I try going zm.mydomain.org/api/host/getVersion.json I get a 404 error... and zmNinja can not access the API neither. For what is worth, I see that no .htaccess files are in any place on the tree. Does anybody know how to fix this situation?
Thank you.
Re: virtualhost configuration and API access
Post by knight-of-ni » Tue Jul 23, 2019 1:09 pm
Just had this conversation here:
viewtopic.php?f=38&t=28409&p=111243#p111216
The short answer is that the package you installed does not have an up to date zm Apache config.
flixter
Post by flixter » Tue Jul 23, 2019 2:41 pm
Indeed, shortly after the post I found out on ZM repo in github a perl script that generates the virtualhost file. I adapted mine and... all works, now.
Thank you anyway for your answer :)
Felix
Users browsing this forum: No registered users and 6 guests
