Web browser and backup
bugmenot
Post by bugmenot » Thu Jul 11, 2019 5:11 pm
What is lightest and best web browser when i run ZoneMinder in Raspberry 3 B?
Is this really easiest way to backup db, just db not images etc? I'm not sure how to run this code.
viewtopic.php?f=32&t=23815#p91360
#!/bin/bash
# Path to the tools this scripts needs
MYSQLDUMP="/usr/bin/mysqldump"
GZIP="/bin/gzip"
FIND="/usr/bin/find"
# Check to see if this script has access to all the commands it needs
for CMD in $MYSQLDUMP $GZIP $FIND; do
  type $CMD &> /dev/null
  if [ $? -ne 0 ]; then
    echo
    echo "ERROR: The script cannot find the required command \"${CMD}\"."
    echo
    exit 1
  fi
done
# Enter SQL database login credentials
USER="root"
PASS="mypass"
# Specify which databases to backup
DB="--all-databases"
# Specify where the databases will be saved to
BKUP_PATH="/path/to/your/backup/folder"
# Format for the timestamp
timestamp="$(date +%Y-%m-%d_%a)"
# Run the backup and compress it
error=0
${MYSQLDUMP} -u${USER} -p${PASS} --events --single-transaction --quick ${DB} | ${GZIP} -9 > ${BKUP_PATH}/Nightly_dB_Backup_${timestamp}.sql.gz
if [ "$?" -ne 0 ]; then
	echo
	echo "WARNING: Mysqldump returned an error!"
	echo
	error=1
fi
# Now find & delete old backups we no longer need
${FIND} ${BKUP_PATH} -maxdepth 1 -type f -mtime +30 -delete
	echo
	echo "WARNING: Find returned an error!"
	echo
	error=1
fi
if [ "$error" -eq 0 ]; then
	echo "Mysql backup script completed successfully!"
fi
kitkat
Re: Web browser and backup
Post by kitkat » Thu Jul 11, 2019 7:11 pm
Maybe, but this will work...
mysqldump -u zoneminder -p --opt zm > zoneminder_backup.sql
Enter the zoneminder database user's password when prompted.
To skip the prompt, such as for automated cron jobs, use the -p parameter...
mysqldump -u zoneminder -p mYp455w0rd --opt zm > zoneminder_backup.sql
bugmenot
Post by bugmenot » Fri Jul 12, 2019 4:12 am
I get this error. I enabled opt_use_auth and maybe it causes it.
mysqldump: got error: 1698: “access denied for user ‘zoneuser’@‘localhost’” when trying to connect
kitkat
Post by kitkat » Fri Jul 12, 2019 10:35 am
I get the same if I use the username and password from /etc/zm/zm.conf, but the credentials in /etc/zm/conf.d/db-user.conf work.
'OP_USE_AUTH' is a ZM thing and won't affect MySQL or MariaDB.
bugmenot
Post by bugmenot » Sat Jul 13, 2019 5:20 am
sudo nano /etc/zm/conf.d/db-user.conf shows empty file.
bugmenot
Post by bugmenot » Sat Jul 20, 2019 5:46 am
I still get this same error:
