within the last couple days my zoneminder stopped seeing my storage folder. Errors of path does not exist and cannot write to content dir make sure it exists and is owned by the web account user.
I have triple checked that all dirs are owned by www-data, i have even created another event folder on seperate drive and changed permissions accordingly and nothing works.....my storage is stuck at 0 percent and will not record anything.. Am i missing something? My storage has over 100 gigs left
Storage Issues
Re: Storage Issues
Are the folders above the storage folder accessible to the ZM user as well as the Apache user?
Using the example from another post, if the storage is at '/data/zoneminder' then the folder /data/ would need permissions of rwxr-xr-x or 755.
Re: Storage Issues
Thanks for the reply but i have been thru the permissions extensively.. i did sudo chown -R 755 /media/3tb/zoneminder and restarted zoneminder and apache...with no luck....still says 0% storage at the top and in the storage config it says 0B of 0B
Re: Storage Issues
If it helps im on ubuntu mate 1804
Re: Storage Issues
Did you also try...
sudo chmod 755 /media /media/3tb
Re: Storage Issues
Kindly tell us a bit about your storage. Did you change from the Zoneminder default? Is the drive a physical drive on the same PC and how is that drive mounted? Is the storage on another device (NAS?) that you have mounted to the Zoneminder machine and if so how is it mounted?
Re: Storage Issues
at first the default folder that was auto configured at install went to zero percent. Same drive as os..the errors say /var/cache/zoneminder cannot write to content dir make sure they exist and are owned by the web account user
Then i tried to make a folder on my data 3 tb drive and chown and chmod it and add it to the storage path in the menu...nope 0%... that drive is mounted in the fstab like this
#/dev/sdc1 /media/ed/Tera/3 ext4 ,user 0 0
/dev/disk/by-uuid/9e7962a4-4166-4255-8eab-fe3161df99c2 /media/ed/Tera/3 auto nosuid,nodev,nofail,x-gvfs-show 0 0
Re: Storage Issues
Systemd is a safer way to mount a drive with Zoneminder. This is my first venture into multiple drives with ZM 1.32.x and someone may say I did something wrong and that is OK because my system works and I'm still willing to learn in spite of being an old guy...
I set up a Ubuntu Bionic server with two hard drives and Zoneminder 1.32.3. The second drive, sdb1, was not mounted. After the basic Zoneminder install I modified the system before I added cameras as follows:
On most Linux distros, you can view the uuid of each of your drives like so:
ls -l /dev/disk/by-uuid
On my system with two hard drives, the items above are as follows:
www-data
/dev/sdb1
7ec50da2-fc67-4ade-89c7-6047710afae2
Your configuration will be different. Options to connect to a network share will be noted herein.
Log in and become root
sudo su
Stop Zoneminder
service zoneminder stop
Create the Systemd Mount Unit whicg mounts the drive To do that create a new folder. I prefer to put mount points under /mnt and give the name of the subfolder the same name as the device or share. In my case, that would be sdb1.
mkdir /mnt/sdb1
When creating mount units with systemd, the filename describing the mount point has to be named in a specific manner. Since the folder I just created is at /mnt/sdb1, one has to name the mount unit mnt-sdb1.mount. Create that file in the /etc/systemd/system folder.
nano /etc/systemd/system/mnt-sdb1.mount
Internal drive: add the following contents, changing the path and uuid to match that of your system:
# systemd mount unit for ZoneMinder event storage
[Unit]
Description=systemd mount unit for ZoneMinder event storage
Before=zoneminder
[Mount]
What=/dev/disk/by-uuid/7ec50da2-fc67-4ade-89c7-6047710afae2
Where=/mnt/sdb1
Type=ext4
Options=defaults,noatime,commit=120,data=writeback
[Install]
WantedBy=multi-user.target
Save and close the editor.
Now enable and start the unit:
systemctl enable mnt-sdb1.mount
systemctl start mnt-sdb1.mount
Make and Set Folder Permissions We've created our primary mount point, but we aren't done yet. First, let's create some folders and set the correct permissions:
mkdir -p /mnt/sdb1/zoneminder/events
chown -R www-data:www-data /mnt/sdb1/zoneminder
Leverage the Power of Systemd If you recall, I mentioned that using systemd to manage your mount points has an advantage over the previous method. With your mount points configured with systemd, you can easily prevent ZoneMinder from starting, should the mount point fail for any reason. Anyone who has ever started ZoneMinder without realizing there was a problem reading from the events folder can tell you what happens when this occurs. You lose all your events, and yes this is by design.
To prevent that from happening we need to modify our zoneminder service file. But first make a copy just in case..
cp /lib/systemd/system/zoneminder.service /lib/systemd/system/zoneminder.service.sav
nano /lib/systemd/system/zoneminder.service
Add entries to the After= and Requires=
# ZoneMinder systemd unit file
# This file is intended to work with Debian distributions
[Unit]
Description=ZoneMinder CCTV recording and surveillance system
After=network.target mysql.service mnt-sdb1.mount
# Remarked out so that it will start ZM on machines that don't have mysql installed
#Requires=mysql.service
Requires=mnt-sdb1.mount
[Service]
#User=www-data
Type=forking
ExecStart=/usr/bin/zmpkg.pl start
ExecReload=/usr/bin/zmpkg.pl restart
ExecStop=/usr/bin/zmpkg.pl stop
PIDFile=/var/run/zm/zm.pid
Restart=on-abnormal
[Install]
Now issue a daemon reload to tell systemd to pick up the change:
systemctl daemon-reload
Should the mount point fail during startup, systemd will prevent the ZoneMinder service from starting with a message stating a failed dependency. Your events are saved from deletion!
Next, create another config file for Zoneminder events
nano /etc/zm/conf.d/03-events.conf
Add the contents: ZM_DIR_EVENTS=/mnt/sdb1/zoneminder/events
Save and Close
In the Zoneminder/Options/Storage create a new storage with the path of: /mnt/sdb1/zoneminder/events
Delete the default storage
Restart Zoneminder
service zoneminder start
www-data
/dev/sdb1
sudo su
Stop Zoneminder
mkdir /mnt/sdb1
[Unit]
Before=zoneminder
[Mount]
Where=/mnt/sdb1
Type=ext4
[Install]
[Unit]
[Service]
#User=www-data
Type=forking
Restart=on-abnormal
[Install]
Save and Close
Restart Zoneminder
