Zoneminder option to send an email?
ski007
Post by ski007 » Tue Jun 25, 2019 7:15 pm
I have a question for more experienced with the Zoneninder program.
I do not know why despite sending emails correctly from the command line
Unfortunately, the sending of e-mails does not work with the program itself.
Sorry for my English. :oops:
echo "Hello, World" | mail -s "My email check" user@linux.pl
echo "Subject: sendmail test" | sendmail -v XXX@linux.pl
both methods work.
However, when checking the logs, nothing happens?
tail -f /var/log/syslog
I must mention that the program itself is installed on the ARM Odreoid HC1 platform. A webcam is under USB / uvc drivers
If it is not a program error or its version under ARM, it is probably the fault of my poor knowledge of Zoneminder :?
my choice in email options:
I installed Zoneminder using a script method :
#!/bin/sh
clear
read -p "This script installs Apache2, Mariadb Server, PHP and Zoneminder 1.32.x on Ubuntu 18.04 ...
Press Enter to continue or Ctrl + c to quit" nothing
clear
read -p "You must be logged in as root using sudo su ...
apt install -y apache2 php mariadb-server php-mysql libapache2-mod-php7.2
clear
read -p "Next secure MySQL server by entering requested information. Press enter to continue" nothing
mysql_secure_installation
clear
read -p "Next we will add the PPA repository, install and configure the system to run Zoneminder.
apt install -y software-properties-common
clear
add-apt-repository ppa:iconnor/zoneminder-1.32
apt update
clear
awk '$0="date.timezone = "$0' /etc/timezone >> /etc/php/7.2/apache2/php.ini
clear
apt install -y zoneminder
systemctl enable zoneminder
service zoneminder start
adduser www-data video
a2enconf zoneminder
a2enmod rewrite
service apache2 reload
clear
read -p "Install complete.Press enter to continue" nothing
clear
kitkat
Re: Zoneminder option to send an email?
Post by kitkat » Wed Jun 26, 2019 11:18 am
Is SSMTP installed?
Can you use it successfully from the command line?
ski007
Post by ski007 » Wed Jun 26, 2019 3:49 pm
Yes ssmtp is installed according to howto:
sudo apt-get update
apt-get install ssmtp
apt-get install mailutils
my ssmtp.conf:
root=XXX@linux.pl
# The place where the mail goes. The actual machine name is required no
# MX records are consulted. Commonly mailhosts are named mail.domain.com
mailhub=mail.linux.pl:587
# Where will the mail seem to come from?
#rewriteDomain=
# The full hostname
hostname=Odroid-HC1
# Are users allowed to set their own From: address?
# YES - Allow the user to specify their own From: address
# NO - Use the system generated From: address
#FromLineOverride=YES
RewriteDomain=linux.pl
UseSTARTTLS=YES
UseTLS=YES
AuthUser=XXX@linux.pl
AuthPass=my_password
my config /etc/ssmtp/revaliases :
root:xxx@linux.pl:mail.linux.pl:587
www-data:xxx@linux.pl:mail.linux.pl:587
check sending from the command line works OK
echo "Hello, World" | mail -s "My email check" xxx@gmail.com
You probably also need to set the filter option
but how to set up an email filter for motion detection
ski007
Post by ski007 » Sat Jun 29, 2019 11:57 am
OK ....I fixed it with this entry in the command line
chmod 777 /etc/ssmtp /etc/ssmtp/*
and for sending an email when motion is detected on the camera, a Filter must be created in the options :shock:
the matter is not intuitive :cry:
regards
snake
Post by snake » Sat Jun 29, 2019 5:11 pm
Guides for email configuration are on the wiki:
https://wiki.zoneminder.com/How_to_get_ ... Zoneminder
https://wiki.zoneminder.com/SMS_Notifications
Filters are fundamental to ZM. They are used for scheduling everything. Heads up, you'll also need to make sure purgewhenfull filter points to the proper storage area if you use a secondary storage in 1.32.
vskatusa
Post by vskatusa » Wed May 13, 2020 9:19 pm
I know this is an old post. I had the same problem. I "enabled less secure app ON" using url https://myaccount.google.com/lesssecureapps?pli=1
https://pasteboard.co/J8eDkRg.png
hth
